MSM problem - site 2 loading site 1 templates
January 13, 2011 3:36am
  • #1 / Jan 13, 2011 3:36am
    archer
    I’m running site 1 (urbanrez.ca) on EE 1.70, and after installing MSM and setting up the templates for the second site (samaqan.ca) the new site, number 2, loads the templates for site 1.
    Example: http://samaqan.ca/index.php?samaqan/news loads the templates for http://urbanrez.ca/index.php?urbanrez/samaqan
    A good clue to the problem might be the fact that the default index.php file at http://samaqan.ca/index.php isn’t loading the css file.
    I’ve tried many solutions, clearing the caches, updating EE to 1.70 from 1.6.9.
    All help appreciated.
  • #2 / Jan 13, 2011 3:41pm
    Are you using any extensions? When you open the the samaquan CP, do you see its own templates?
  • #3 / Jan 13, 2011 4:13pm
    archer
    I’m not using any extensions except MSM, and yes, I can view and edit all the Samaqan templates. In fact, all of the CP functionality is working perfectly for both sites.
    FYI here are my relevant CP General Configuration settings:
    Enable Multiple Site Manager - Yes
    Name of your site’s index page - index
    URL to the root directory of your site - http://samaqan.ca/
    URL to your Control Panel index page - This is exactly the same as the first, working site setting
    URL to your “themes” folder - This is exactly the same as the first, working site setting
    Theme Folder Path - This is exactly the same as the first, working site setting
    Archer
  • #4 / Jan 14, 2011 12:11pm
    Hi, archer -
    Can you show us your path.php for Site 2?  If you can copy/paste that in here that would help I’ll be specifically looking for site_name variable.
    Can you also post the two site short-names for each of the Sites, as set in your CP?
  • #5 / Jan 14, 2011 2:22pm
    archer
    Hi Lisa!
    Happily, I’ve just figured it out, although what the problem was I still don’t know. I exported my templates, deleted the second site and started it again from scratch. That did it.
    Something got corrupted somewhere, I suppose.
    Thanks for your help,
    Archer
  • #6 / Jan 14, 2011 3:19pm
    archer
    One small issue remains. In the CP, top right corner, “Current User: Archer” the green background is weird and corrupted. It looks different in Safari and Firefox, screen grabs attached.
  • #7 / Jan 14, 2011 7:22pm
    Hi, archer.
    You might try re-uploading your images again in binary mode. I’ve seen it happen before.
    Does that help?
