My comments are appearing in the wrong order
January 07, 2011 9:38pm
Subscribe [7]
  • #1 / Jan 07, 2011 9:38pm
    brebre
    My comments are appearing in the wrong order… I want the latest at the top… currently it appears at the bottom. If I reverse sort=“asc|desc” there is no difference.
    Any ideas where I am going wrong?
    {exp:comment:entries orderby="most_recent_comment" sort="asc|desc"}
    {/exp:comment:entries}
    thank Lance
  • #2 / Jan 08, 2011 12:07am
    Jeremy Bise
    I think it should be orderby=“date” sort=“asc”.
  • #3 / Jan 08, 2011 5:09am
    brebre
    normally yeh, but not working on my comments.
  • #4 / Jan 08, 2011 7:23am
    brebre
    {exp:comment:entries sort="desc" orderby="date"}
    is actually the correct ‘order’ that works… this is weird.
    PLUS there is a bug in the comments… it seems with a count over 18 things go screwy.
    http://ellislab.com/forums/newreply/176862/
  • #5 / Jan 08, 2011 1:23pm
    Jeremy Bise
    That is weird.
  • #6 / Jan 10, 2011 2:47am
    brebre,
    the bug you refer to has been fixed for next release. Is everything working ok for you now?
    If your comments were ascending then it would start with the first comment. Descending starts with the latest. It works the same across the board in EE
  • #7 / Jan 14, 2011 7:41pm
    24here
    I also have this problem, comments not sorting correctly, even I use
    it seems to be working correct
  • #8 / Jan 15, 2011 3:39pm
    Greg Salt
    Hi 24here,
    Thank you for the update.
    @brebre, how are you getting on?
    Cheers
    Greg
  • #9 / Feb 16, 2011 5:48pm
    markphillip
    Which is the bug that has been fixed ... the sort order problem or the ‘over 18 things get screwy’ problem?
    I’m having the sort order problem right now ... regardless of the whether I sort ASC or DESC the generated template sorts in ASC.
    Is there a workaround for this?
  • #10 / Feb 17, 2011 8:35am
    Hi, Mark. both have been fixed in EE2.1.4 beta.
    {exp:comment:entries limit="20" sort="desc" orderby="title" channel="news" dynamic="off"}
        <li>
            <em>{author}</em> on <a href="http://{url_title_path="><strong>{title}</strong> - {comment_id} - {count}</a>
        </li>
