Channel Entries API - missing index 'field_fmt'
January 07, 2011 8:55am
Subscribe [5]
  • #1 / Jan 07, 2011 8:55am
    Chroma Sports
    I’m working on importing data (mentioned it in another thread, but posted as tracerstar), and I’m getting some PHP errors.
    Using this bit of code ($entry is an array of data I am inserting):
    $channel_id = 1;
    $entry_data = array(
        'title' => $entry['headline'],
        'entry_id' => 0,
        'entry_date' => strtotime($entry['dateTime']),
        'field_id_1' => $entry['content'],
        'field_ft_1' => 'xhtml',
        'field_id_2' => $entry['teaser'],
        'field_ft_2' => 'none',
        'field_id_3' => $entry['img_field'],
        'field_ft_3' => $entry['img_field_ft']
    $this->EE->api_channel_entries->submit_new_entry($channel_id, $entry_data);
    I’m getting the error:
    A PHP Error was encountered
    Severity: Notice
    Message: Undefined index: field_fmt
    Filename: api/Api_channel_entries.php
    Line Number: 943
    I’ve traced it back through the API to be in the library file Api_channel_fields.php The function which creates the settings for the custom fields is not selecting the field “field_fmt” from the database, but this field is trying to be read in the method “_base_prep” on line 943 of the Api_channel_entries.php library file.
    I’ve fixed this by adding to the Api_channel_fields.php the necessary code to select and set this field, but I just wanted check if this is a bug or not?
    Interestingly, this bit of code in the Api_channel_entries.php file (lines 939 - 941) seem to suggest that a data field named “field_ft_field_id_X” is required (where X is an int of the field ID).
    $id = 'field_id_'.$id;
    if ($data['entry_id'] == 0 && ! isset($data['field_ft_'.$id]))
    Is this another bug, or am I missing something?
    Ben.
  • #2 / Jan 07, 2011 2:54pm
    Barry Cogan
    HI Chroma,
    Please report these as bugs here.
    Thank you,
    Barry Cogan
  • #3 / Jan 10, 2011 5:32pm
    Chris Chiles
    Chroma,
    I ran into this same issue and filed a bug report here. Looks like it’ll be fixed in the next release.
    - Chris
  • #4 / Jan 10, 2011 5:45pm
    Thanks for letting us know. Please don’t hesitate to post again in case there’s anything else.
