MSM and unknown $system_path on second domain :-(
January 01, 2011 8:07am
  • #1 / Jan 01, 2011 8:07am
    manimac
    Hi all! i have a classic newbie problem..
    i have bought two domain on the same host (register.it)
    each domain have basepath “/” so i dont have httpdocs or usr/bin/etc, just a trailing slash /
    so i can’t set MSM ‘cause i dont know the $system_path from my second domain to the primary domain where i’ve installed EE2.
    Also the hosting company dont say nothing about this!
    ..and they say it’s not a possible feature to know for clients the full server path!
    I try to put on my root of my second domain this code without success, he say always “/”:
    <?php
    $path = getcwd();
    echo "This Is Your Absolute Path: ";
    echo $path;
    i have access only to php.ini
    it can help me with my issue?
    ..or I have other ways to set MSM ??
    please let me know if somebody can help me
    thank you!
    vito.
  • #2 / Jan 02, 2011 8:44am
    Greg Salt
    Hi Vito,
    This sounds like you’ve purchased 2 separate hosting accounts where in fact you only need one but the second domain would need to be aliased to your first one - some hosts calls these addon or parked domains. Your hosting provider should have this facility available for you and should then be able to tell you whether an aliased domain can have its own subdirectory or path. Please contact them to check this.
    Cheers
    Greg
  • #3 / Jan 02, 2011 10:10am
    manimac
    thank you Greg, i’m waiting for an hosting provider answer..
    anyway in the hosting control panel i have access to the DNS configuration.
    I suppose i can alias my second domain to my primary domain witch EE is installed, it’s right?
  • #4 / Jan 04, 2011 1:48am
    WeLive,
    It will need to be aliased to it’s own folder within the primary domains structure and not to your primary domain specifically. The domains will have to exist within the same hosting account as Greg says.
    Let us know what your host says when they come back to you
