Something cool from wordpress,but what is it?
December 19, 2010 6:48am
Subscribe [5]
  • #1 / Dec 19, 2010 6:48am
    phpserver
    I have come across this code for storing theme options in wordpress and i would like to know what this format of storing stuff is to use it in my future projects.
    a:34:{s:15:"generalsettings";N;s:0:"";N;s:12:"color_scheme";s:0:"";s:9:"site_name";s:0:"";s:11:"custom_logo";s:0:"";s:10:"twitter_id";s:48:"also include facebook username:this is a comment";s:13:"header_teaser";s:10:"customtext";s:12:"teaser_style";s:0:"";s:13:"teaser_custom";s:0:"";s:13:"cufon_disable";N;s:18:"breadcrumb_disable";N;s:14:"analytics_code";s:0:"";s:8:"homepage";N;s:11:"teaser_text";s:0:"";s:13:"teaser_button";s:2:"26";s:16:"mainpage_content";s:0:"";s:19:"home_teaser_disable";N;s:14:"slider_disable";s:1:"1";s:12:"slider_speed";s:0:"";s:15:"homepage_slider";s:6:"custom";s:15:"slider_showcats";s:0:"";s:12:"slider_count";s:0:"";s:4:"blog";N;s:9:"blog_page";s:0:"";s:16:"blog_excludecats";s:0:"";s:21:"related_popular_posts";N;s:16:"social_bookmarks";N;s:12:"about_author";N;s:7:"sidebar";N;s:14:"footersettings";N;s:11:"footer_text";s:0:"";s:14:"footer_include";s:0:"";s:11:"navsettings";N;s:12:"show_hide_pg";s:0:"";}
    What is this format and where can i get more information about it?
  • #2 / Dec 19, 2010 7:19am
    phpserver
  • #3 / Dec 19, 2010 7:40am
    Sire
    Do you mean the json format?  Look at json_encode and json_decode
    http://php.net/manual/en/function.json-encode.php
    http://php.net/manual/en/function.json-decode.php
  • #4 / Dec 19, 2010 8:02am
    phpserver
    I was thinking there was more to it than the json but i have now figured it all out.
  • #5 / Dec 19, 2010 4:53pm
    moodh
    That kind of data is achieved by using serialize() and unseralize() on a simple array to store it in text format, it’s NOT JSON.
    This is JSON:
    {"bindings": [
    {"ircEvent": "PRIVMSG", "method": "newURI", "regex": "^http://.*"},
          {"ircEvent": "PRIVMSG", "method": "deleteURI", "regex": "^delete.*"},
          {"ircEvent": "PRIVMSG", "method": "randomURI", "regex": "^random.*"}
  • #6 / Dec 19, 2010 6:47pm
    phpserver
    I never said it was json,i was reacting to Sire encode and decode links.Curious:Does expression engine implement such a format:
    a:34:{s:15:"generalsettings";N;s:0:"";N;s:12:"color_scheme";.....
  • #7 / Dec 20, 2010 11:52am
    Joseph Wensley
    EE uses serialized data for reverse relationships and extension settings; CI uses it for session data stored in the DB.
  • #8 / Dec 20, 2010 12:48pm
    phpserver
    Is there a decent tutorial where i can learn more about this format?
  • #9 / Dec 20, 2010 12:58pm
    samitrimal
    i think its using
    serialize()
    function . may be it will help u
  • #10 / Dec 20, 2010 1:19pm
    phpserver
    It looks like it,but its amazing,i have been looking real hard for information on wp forums on it and nothing pops,nothing,zip.
  • #11 / Dec 20, 2010 1:37pm
    phpserver
  • #12 / Jan 03, 2011 10:51am
    InsiteFX
    This is how CodeIgniter does it in the Session Class.
     * Serialize an array
     * This function first converts any slashes found in the array to a temporary
     * marker, so when it gets unserialized the slashes will be preserved
     * @access    private
     * @param    array
     * @return    string
    function _serialize($data)
        if (is_array($data))
            foreach ($data as $key => $val)
                if (is_string($val))
                    $data[$key] = str_replace('\\', '{{slash}}', $val);
        else
            if (is_string($data))
                $data = str_replace('\\', '{{slash}}', $data);
        return serialize($data);
     * Unserialize
     * This function unserializes a data string, then converts any
     * temporary slash markers back to actual slashes
     * @access    private
     * @param    array
     * @return    string
    function _unserialize($data)
        $data = @unserialize(strip_slashes($data));
                    $data[$key] = str_replace('{{slash}}', '\\', $val);
            return $data;
        return (is_string($data)) ? str_replace('{{slash}}', '\\', $data) : $data;
    InsiteFX
  • #13 / Jan 14, 2011 3:04pm
    phpserver
    Wow,thanks.
  • #14 / Jan 24, 2011 12:27am
    Vheissu
    Pyrocms also does the same thing and serializes module options, etc. A few applications built on CI do it, including SiteManPro.
