I am rocking EE version 2.1.2 Build 20101215.
I reproduced this on a fresh install. I would like to know if I am doing something incorrectly, or if this is a bug.
What I am trying to accomplish is a select dropdown custom field with a default text formatting of None.
Here are the options I am using:
Field Type: Select Dropdown
Field Label: Dropdown
Field Name: dropdown
Field Instructions:
Is this a required field?: No
Is field searchable?: No
Show this field by default?: Yes
Field Display Order: 2
Default Text Formatting for This Field: None
Allow override on publish page?: No
Populate the menu manually: One, Two, Three, Four (these values are all on separate lines in the textarea field)
The problem comes when I try to display the value of the dropdown - it gets wrapped in paragraph tags. To set the formatting to None I must go back to the Edit Field settings, change the Default Text Formatting for This Field to something else, save, then set the Default Text Formatting for This Field back to None (and checking Update all existing channel entries with your new formatting choice?)
