Is it ever possible to use one plugin (or module) output as parameter argument for another plugin (or module)
December 01, 2010 8:36pm
  • #1 / Dec 01, 2010 8:36pm
    Is there any way to accomplish, roughly, this?
    {exp:plugin1:method arg="{exp:plugin2:method}"}
    I’ve tried a number of different approaches.
    Approach 1:
    Result: Plugin1->method’s arg parameter value is the string, ‘{exp:plugin2:method}’, and it’s never parsed.
    Approach 2:
    My understanding of the parsing order suggests that this might have different results, but apparently it does not.
    {preload_replace:replaced="{exp:plugin2:method}"}
    {exp:plugin1:method arg="{replaced}"}
    Result: The arg parameter has the same value as approach 1.
    Approach 3:
    First I define a snippet (snip), whose content is:
    . Then in the template:
    {exp:plugin1:method arg="{snip}"}
    Result: Same as approaches 1 and 2.
    Approach 4:
    Noting that plugins are processed in the order they appear, I have even tested simply placing an instance of {exp:plugin2:method} before the {exp:plugin1:method} call. My thinking is that I could wrap this first call in a regex replacement plugin in order to suppress output, but that it would trigger Plugin2’s parsing first.
    Result: Plugin1->method’s arg parameter value is the temporary hash placeholder for Plugin2->method’s output (MD5 I believe) that the Template class reserves until later.
    Is there any way to do this? Am I missing something totally obvious?
  • #2 / Dec 02, 2010 4:01pm
    I am afraid that’s not a feasible approach. Your best option would be to combine the code of the two plugins into a single add-on, or otherwise use some PHP.
  • #3 / Dec 02, 2010 4:15pm
    In practice this means it’s impossible to use a third-party plugin to populate parameters of a first-party module. Something as simple as passing an entry_id to the channel module.
    This seems severely limiting to me, and I don’t think duplicating first-party modules or requiring PHP in templates should be the answer.
  • #4 / Dec 02, 2010 4:29pm
    Well, you can nest plugins, like so:
    {exp:foo}
      {exp:bar my_foo="{my_foo}"}
    {/exp:foo}
    where {my_foo} would be created by exp:foo. There are some examples of this in the docs.
  • #5 / Dec 02, 2010 6:38pm
    You’re right. I guess that’s the workaround I’ll go for. But it would be nice to not have to do that. For anyone interested, I added this to my plugin’s constructor:
    if(($tagdata = $this->EE->TMPL->tagdata) !== false && trim($tagdata) !== '') {
        // Cache public methods (class needs a static $public_methods declaration)
        if(!isset(self::$public_methods)) {
            self::$public_methods = array();
            $methods = get_class_methods($this);
            foreach($methods as $method) {
                if($method == get_class($this) || $method == '__construct') {
                    continue;
                $reflection = new ReflectionMethod(get_class($this), $method);
                if($reflection->isPublic()) {
                    self::$public_methods[] = $method;
            self::$public_methods = implode('|', self::$public_methods);
        $tagdata = preg_replace_callback('/\{(' . self::$public_methods . ')\}/',
            array($this, 'tagdata_callback'), $tagdata);
        $this->return_data = $tagdata;
    And this callback method:
    private function tagdata_callback($matches) {
        $method = $matches[1];
        return $this->$method();
    Note that in order for this to work at all, the outer plugin needs to be parse=“inward”.
    Edit: And due to relying on Reflection, it won’t work in PHP4. For that, you can maintain a manual list of public methods.
  • #6 / Dec 03, 2010 11:01am
    Thanks for sharing your solution with us. Please start a new thread as needed.
