Errors after upgrade from 1.6.8 to 2.1.1
December 01, 2010 1:45pm
Subscribe [4]
  • #1 / Dec 01, 2010 1:45pm
    Gert Timmerman
    After the upgrade from 1.6.8 to 2.1.1 the site wont work, i get the following error:
    Site Error: Unable to Load Site Preferences; Invalid Preference Data
    I have restored the exp_sites table, but that dont help me.
  • #2 / Dec 02, 2010 8:02am
    Hi, Gert. Did you make any sort of changes to the exp_sites table by editing it?
    The exp_sites table from 1.6.x isn’t going to work with EE2.x.
  • #3 / Dec 02, 2010 8:16am
    Gert Timmerman
    no, i didn;t change anything, before the upgrade. After the upgrade the preferences in the exp_sites have the values ‘czowOiIiOw==’
    I had already reverted the upgrade and have now 1.6.8 again. I’m now going to upgrade to 1.7.0 first in the development server and then try again to upgrade to 2.1.1.
    Do you know what caused this error, because lots of people had this error i had seen on the forums?
  • #4 / Dec 02, 2010 11:04am
    Gert Timmerman
    I have made a test section locally and upgraded without any problems from 1.6.8. to 1.7.0. Then I cleared the cache and run the install wizard of 2.1.1, but after the step when the database tables are converting to 2.0.0. the wizard went to a blank screen. Now i get the error :
    Fatal error: Call to undefined method CI_Config::site_prefs() in /Users/xxxxxxxxx/javel/expressionengine/libraries/Core.php on line 150
    When i look in the exp_sites table this value is in the site_system_preferences field: YToxMDA6e3M6MTU6ImVuY3J5cHRpb25fdHlwZSI7czo0OiJzaG…
    I also see the 1.x.x table names, for example i dont see a exp_channel table, but the exp_weblog table still exists ..
    What can i do??
  • #5 / Dec 03, 2010 3:21am
    Gert,
    Can you confirm that all the folders made it up there from your 2.1.1 download like the codeigniter folder?
    One other thing to try is. You are renaming your system folder right? Rename it back to system and update any reference to it. Then try the upgrade again
  • #6 / Dec 07, 2010 6:25pm
    Gert Timmerman
    i have tried with the default system folder name, and i still get the blank page after the step where the database is converted to 2.1.1.
    I have set the debug variable to 1, and now i get a error message:
    Fatal error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 40 bytes) in /Users/xxxxxxxxxx/Sites/xxxxxxxx/system/codeigniter/system/database/drivers/mysql/mysql_result.php on line 147
    is this a bug, do i have set the max_upload_size bigger in php.ini??
  • #7 / Dec 08, 2010 4:36pm
    It looks as though you’re running out of memory, yes. Can you try to increase that amount?
  • #8 / Dec 08, 2010 5:52pm
    Gert Timmerman
    ok, that works, but now i get the following error:
    A Database Error Occurred
    Error Number: 1153
    Got a packet bigger than 'max_allowed_packet' bytes
    UPDATE `exp_forum_posts` SET `post_date` = `post_date` + 3600 WHERE `post_id` IN ('6','7','10','...........')
    Filename: updates/ud_200.php
    Line Number: 662
    the list of post_id IN is huge,
  • #9 / Dec 09, 2010 6:23am
    Gert Timmerman
    Yeah! I have updated to 2.1.1!!!
    I have setted the mysql max_allowed_packet to a larger number and now i have succesful updated to the newest version.
    Thanx for your support!
  • #10 / Dec 09, 2010 4:50pm
    Thanks for letting us know. Please post again as needed.
