Another "system folder path does not appear to be set correctly" question
December 01, 2010 1:57am
Subscribe [4]
  • #1 / Dec 01, 2010 1:57am
    OutdoorGrrl
    I’m upgrading from EE 1.5.2. I think I’ve followed the directions to a T, but I’m getting the message that says “Your system folder path does not appear to be set correctly. Please open the following file and correct this: index.php” when I try to run the update wizard.
    I checked newsystemname/expressionengine/config.php and the code appears correct:
    $conf['system_folder'] = "not_system";
    $conf['cp_url'] = "http://www.nwoutdoorgrrl.com/not_system/index.php";
    (My original config file said “conf” not “config.” Would that make a difference?)
    I also checked newsystemname/index.php to be doubly sure I updated the system path:
    $system_path = "http://www.nwoutdoorgrrl.com/not_system";
    Still, no joy. Any ideas?
  • #2 / Dec 01, 2010 3:33pm
    What steps have you taken so far? I suppose you have uploaded a fresh set of files. Have you then run the updater? Is that when you get the error?
  • #3 / Dec 01, 2010 5:07pm
    OutdoorGrrl
    I started by deleting the files in the system directory and themes directory, then I uploaded the new files into the directories specified and reuploaded the old files as described in step 2 (http://ellislab.com/expressionengine/user-guide/installation/update_from_1.x.html). I changed the permissions as instructed in step 3. When I tried running the update wizard, I got the error message.
  • #4 / Dec 02, 2010 10:58am
    Hi, OutdoorGrrl. Do you still have your original 1.5.x database?
    If you do, I suggest doing your update in stages. Instead of going from 1.5.x to 2.1.1, try to go to 1.7.0 instead. (You can download 1.7.0 from the same place you downloaded 2.1.1.
    Once that upgrade is working, then we’ll get to the 2.1.1 install.
    Does that make sense?
  • #5 / Dec 02, 2010 4:48pm
    OutdoorGrrl
    I successfully restored v 1.5.2, but I’m having trouble upgrading to v 1.7.0. I’ve downloaded the EE 1.7.0 documentation, but I’ve gotten stuck at step 2 - uploading the files. The instructions tell me to upload and replace the folders listed below:
    system/core/
    system/cp/
    system/db/
    system/language/
    system/lib/
    system/modules/
    system/plugins/
    system/updates/
    system/update.php
    system/utilities/
    None of these folders, except cp and modules, are in the packet of stuff that I downloaded. Am I missing something?
  • #6 / Dec 03, 2010 11:26am
    Have you made sure you downloaded the correct version? I just did and the “system” directory in the .zip has all these directories (and then some).
  • #7 / Dec 03, 2010 11:28am
    OutdoorGrrl
    I’ve downloaded the ONLY thing in my downloads area related to v 1.7.0. It’s titled “ExpressionEngine 1.7.0 Documentation.” There is NO system folder in it.
  • #8 / Dec 03, 2010 2:01pm
    OutdoorGrrl
    I think the problem might be that the only thing listed under full version downloads is EE 2.x commercial license update. There is no 1.7.0 license update downloads, only the documentation.
  • #9 / Dec 04, 2010 4:15pm
    Greg Salt
    Hi OutdoorGrrl,
    If you click the download link next to your EE 2x commercial licence you will see the Licence Agreement page. At the bottom of that, just above the ‘Accept Licence and Download’ button there is a radio button where you can choose which version of EE to download.
    Cheers
    Greg
