Parsing of conditionals in an add-on tag pair
November 16, 2010 9:11pm
  • #1 / Nov 16, 2010 9:11pm
    GoElement
    I am using the taxonomy add-on, and within the {exp:taxonomy:nav} tag set (documentation here) I am trying to do a conditional, as follows:
    {exp:taxonomy:nav tree_id="{embed:taxonomy_root}" depth="10" display_root="no" ul_css_id="mainmenu"}
      < a {if node_level != "1"}class="sub"{/if} href="{node_url}">{node_title}</a>
    {/exp:taxonomy:nav}
    I was surprised to find that didn’t work.
    What does work is if I change the conditional to use a quoted variable, like so:
      < a {if "{node_level}" != "1"}class="sub"{/if} href="{node_url}">{node_title}</a>
    {/exp:taxonomy:nav}
    However, the FAQ advises against this syntax.
    So, 3 questions:
    1) Do conditionals get parsed differently for add-ons than for the channel module?
    2) Is there some other way that I could write this to accomplish my desired effect?
      2a) Otherwise, is my working code “safe” despite the advice of the FAQ?
  • #2 / Nov 16, 2010 9:15pm
    Hi, GE -
    This is something you should take up with the author.  Generally speaking, this can be an indicator that the variables aren’t being run through prep_conditionals.
    I’m not familiar enough with this add-on to know if it’s safe; generally, it’s not safe if it’s taking user submitted input, such as URL segments.
  • #3 / Nov 16, 2010 9:24pm
    GoElement
    Thanks for the quick reply.  I’ve posted in the taxonomy thread over in the community forums asking for the author’s input.
  • #4 / Nov 16, 2010 9:27pm
    Hi, GE - add-on support isn’t handled on our forums.  Iain (the author) will likely ask you to post at his preferred support location, which appears to be on the Devot-ee support forums. =)
  • #5 / Nov 17, 2010 5:29pm
    Looks like this is fixed in v 1.07.  Please start a new thread if you need anything else!
