Feeding FeedGrab Plugin from a Weblog Entries Tag
November 15, 2010 12:52am
  • #1 / Nov 15, 2010 12:52am
    [email protected]
    I am hoping to be able to create a weblog that I can simply add URL’s to which will automagically feed the “go” template I am using for Feedgrab.
    Here’s what I currently use:
    {exp:feedgrab url="http://feeds.feedburner.com/TechCrunch" weblog="10" title="title" date="pubDate" use="link|description" fields="iphone_link|iphone_description" refresh="10"}
    The issue here is that each time I want to add a new feed I have to hand code the additional loop.
    What I want to do is this:
    {exp:weblog:entries weblog="feed_find"}
      {exp:feedgrab url="{feed_url}" weblog="10" title="title" date="pubDate" use="link|description" fields="iphone_link|iphone_description" refresh="10"}
    {/exp:weblog:entries}
    Where the weblog “feed_find” is a cache of feed url’s that I input.
    The problem I am having is that I have the exp:feedgrab inside of the exp:weblog:entries tag and I think this is causing a parsing issue. Is there a way around this?
    This is the error I get with the above snippet:
    Warning: MagpieRSS: Failed to fetch /home/joshmaxr/public_html/afdl_admin_sys/plugins/pi.feedgrab.php on line 1793
    Notice: Trying to get property of non-object in /home/joshmaxr/public_html/afdl_admin_sys/plugins/pi.feedgrab.php on line 165
  • #2 / Nov 16, 2010 8:21am
    Boyink!
    Hey Josh -
    If you think it’s a parse issue try embedding the feedgrab code into it’s own template and passing embed variables as needed.
  • #3 / Nov 16, 2010 11:20am
    Mike,
    Thanks for the advice. I want to make sure I understand your advice. I set up an embed “feed_embed” with the following:
    I kept my “go” template and made the following changes, most notably the last weblog entries loop which embeds the feedgrab code:
      {embed="embeds/feed_embed"}
    {/exp:weblog:entries}</code></pre>
    Still getting the same error as above.
    Warning: MagpieRSS: Failed to fetch {feed_url} (HTTP Error: Invalid protocol “”) in /home/joshmaxr/public_html/afdl_admin_sys/plugins/pi.feedgrab.php on line 1793
  • #4 / Nov 16, 2010 11:53am
    Boyink!
    I don’t see where you are passing the embed variable to the embedded template.
  • #5 / Nov 19, 2010 2:02am
    Mike,
    Thanks for having a look:
    I have in my go.php template the following:
      {embed="embeds/feed_embed" my_url="{feed_url}"}
    In my feed_embed.php I have this:
    {exp:feedgrab url="{embed:my_url}" weblog="10" title="title" date="pubDate" use="link|description" fields="iphone_link|iphone_description" refresh="10"}
    But I am still getting this error:
    Could you let me know if I addressed your feedback
    Many thanks.
    Josh
  • #6 / Nov 19, 2010 8:16am
    Boyink!
    Yep - the first time you posted the outer loop the embed variable was not getting passed into the embedded template.
    Does the plugin grab the feed correctly when used on it’s own and with hardcoded URL?
  • #7 / Nov 19, 2010 11:05am
    Mike,
    Yeah the plugin works fine on it’s own with the url hardcoded.
    I made a post to the Brandnewbox forums a few days ago but no luck, http://brandnewbox.co.uk/forums/viewthread/191/.
    Any ideas what I might try next?
  • #8 / Nov 19, 2010 11:08am
    Boyink!
    I got nuthin’ 😉
