Something odd is happening which is affecting the main site and secondary site which are coded in different ways.
I am developing a new channel on the secondary site. The comment form shows a single article entry and provides a comment form with the obligatory preview and submit buttons.
The comment form has the parameters:
{exp:comment:form preview="{myTemplateGroup}/preview" channel="{myChannel}"}On entering some dummy comments and hitting the preview button I get
1) no part of the channel entry - no result from channel:entries tag (identical to that on the comments template)
2) the preview comment + form - wanted
Looking at the title bar it is clear that it has found the preview template. For some reason the url shown in the browser bar is just the base {site_url} which presumably explains why the channel entry and prior comments aren’t displayed. I don’t know why it is dong this, however.
I checked with the other channel on the secondary site which had previously worked - this does exactly the same i.e. doesn’t work. I’ve also checked the main site which has 2 channels and again this doesn’t now work. They don’t share templates nor redirects or anything that I can see.
If you look at http://systems-thinkers.org/index.php/articles/comments/system_of_systems_sos_is_an_arrangement_not_a_type you’ll see the problem (still undergoing development and not in the public domain)
Any clues gratefully received.
EE v2.1.1 Build: 20101020
