RSS Feed Help -- Please...
November 09, 2010 10:52pm
Subscribe [4]
  • #1 / Nov 09, 2010 10:52pm
    jupebox
    I am volunteering for a church, and I am having trouble setting up an RSS feed…
    http://www.uptownbaptistchurch.org/blog/rss
    Could someone help me with what I am doing wrong?
    I tried it in FeedBurner, but it says it’s not a valid xml file.  (I selected rss in the template type.)
    I’ve been working on this for a long time, with no luck… any help would be greatly appreciated.
  • #2 / Nov 10, 2010 3:04am
  • #3 / Nov 10, 2010 11:29am
    Welcome to the ExpressionEngine forums, jupebox!
    Since you’re new to the EE forums, have you seen EEWiki:// How to Post a Support Request?
    Dylan, thanks for the assist.
    jupebox, do the entries Dylan has linked to help?
  • #4 / Nov 11, 2010 1:14am
    jupebox
    Unfortunately, I’m not sure why FeedBurner would reject the RSS.  I tried to use the template…
    For example, look at this error message when I try to validate the RSS:
    http://feedvalidator.org/check.cgi?url=www.uptownbaptistchurch.org/blog/rss/
    I’m not sure what to do next.
    Joel
  • #5 / Nov 11, 2010 12:00pm
    jupebox
    I am using the EE RSS template, but feedburner gives me the following error message:
    “The URL does not appear to reference a valid XML file.”
  • #6 / Nov 11, 2010 6:38pm
    Hi, jupebox. Can you post what exactly you have in your RSS feed template? Which build/version of EE2.x are you using? You can find that out at the bottom of any control panel page. (In the footer.)
  • #7 / Nov 11, 2010 9:35pm
    jupebox
    Thanks for helping.  I am using EE 1.6.7
    Below is exactly what is in my RSS template…
    {assign_variable:master_weblog_name="blog"}
    {exp:rss:feed weblog="{master_weblog_name}" debug="yes"}
    <?xml version="1.0" encoding="{encoding}"?>
    <rss version="2.0"
        xmlns:dc="http://purl.org/dc/elements/1.1/"
        xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
        xmlns:admin="http://webns.net/mvcb/"
        xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
        xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
        <title>{exp:xml_encode}{weblog_name}{/exp:xml_encode}</title>
        <link>{weblog_url}</link>
        <description>{weblog_description}</description>
        <dc:language>{weblog_language}</dc:language>
        <dc:creator>[email protected]</dc:creator>
        <dc:rights>Copyright {gmt_date format="%Y"}</dc:rights>
        <dc:date>{gmt_date format="%Y-%m-%dT%H:%i:%s%Q"}</dc:date>
        <admin:generatorAgent rdf:resource="http://expressionengine.com/" >
    {exp:weblog:entries weblog="{master_weblog_name}" limit="10" rdf="off" dynamic_start="on" disable="member_data|trackbacks"}
        <item>
          <title>{exp:xml_encode}{title}{/exp:xml_encode}</title>
          <link>{title_permalink=blog/article}</link>
          <guid>{title_permalink=blog/article}#When:{gmt_entry_date format="%H:%i:%sZ"}</guid>
          <description>{exp:xml_encode}{summary}{body}{/exp:xml_encode}</description>
          <dc:subject>{exp:xml_encode}{categories backspace="1"}{category_name}, {/categories}{/exp:xml_encode}</dc:subject>
          <dc:date>{gmt_entry_date format="%Y-%m-%dT%H:%i:%s%Q"}</dc:date>
        </item>
    {/exp:weblog:entries}
        </channel>
    </rss>
    {/exp:rss:feed}
  • #8 / Nov 12, 2010 9:39am
    Your feed contains encoded entities, like & lt;title & gt; Are they part of the original data?
  • #9 / Nov 12, 2010 10:36am
    jupebox
    Yeah, that seems strange.  Feed Valitor made a note of that.
    I didn’t add those, but not sure where they are coming from.
    (Also, is “channel” an appropriate tag for EE 1.6.7?)
  • #10 / Nov 12, 2010 4:53pm
    Have you tried the code found in this wiki article?
    http://expressionengine.com/wiki/How_can_I_use_HTML_to_format_my_RSS_feed/
    If that still doesn’t work for you, you might want to consider upgrading your version if for no other reason that to refresh your code base.
    Does that help?
