Hi folks,
On this page: http://ellislab.com/expressionengine/user-guide/installation/update.html, there’s a line that reads:
“In your ExpressionEngine Control Panel, go to Tools > Data > Clear Caching. Select All cache files and submit the form to clear out your caches.”
In the CP in EE 2.1.0, the screen actually shows the option All caches, not All cache files. So this line should be changed to
“In your ExpressionEngine Control Panel, go to Tools > Data > Clear Caching. Select All caches and submit the form to clear out your caches.”
Ruthie
