Can't publish or edit
November 01, 2010 7:45pm
  • #1 / Nov 01, 2010 7:45pm
    Saso
    Hi guys
    There is some strange error when i try to publish new entry or edit the old one.
    When i try to publish new entry, nothing happens, i just became option to download my http://mypage.com/admin.php file (this is my CP link) - this is on Firefox.
    The same job on Chrome gives me error, as seen an attached image.
    I’m using latest EE2, with installed Wygwam and Chanell images modules.
    When i remove custom filds assigned to cahnnels, then i can open publish form (which is useless without custom fields).
    I have successfully installed EE2 and all things on CP works, except publishing and editing. 😊
  • #2 / Nov 01, 2010 8:26pm
    codeM
    Hi
    If you disable Channel images are u able to publish or edit?
    If so try downloading latest channel images version which is 2.1.6 I believe
    If not try disabling all third party modules and re-enabling them one by one to see which one is causing you a problem then go the vendor for support on the issue 😉
    Hope it helps a bit
  • #3 / Nov 02, 2010 7:52am
    Saso
    Hi
    Thanks for your answer.
    I have solved that problem, although i dont know, what was wrong.
    First i try with new test chanell and with new custom fields and it works. (so, nothing wrong with installed modules)
    Then i try publish againg with old channels and it did want to work. So i deleted all custom fields and create new ones (exact the same as previus, with the same names).
    Now everything works, but i hope this problem will not come again, because this solution is not what i want to do one more time. 😊
    Saso
  • #4 / Nov 02, 2010 5:05pm
    Glad to hear you’re up and running. Please post again as needed.
