member_group variable in php
November 01, 2010 6:39pm
  • #1 / Nov 01, 2010 6:39pm
    rblitadmin
    Hi! I’m trying to grant access to content based on a user’s member group using php. Is there a better way to access it in php than {member_group}? I’ve been able to pull out custom field data in php, but the {member_group} variable gives me problems. If I do this:
    <?php
        $memberGroup = "{member_group}";
        echo $memberGroup;
    I get the member group out in a string form. Its funny though because the string length is 14 characters and $memberGroup[0]=”{" and $memberGroup[1]="m" and $memberGroup[2]="e" and so until you get {member_group}. If you actually display all $memberGroup[0] to $memberGroup[13] in a row you get out the member group in string form again. It seems what EE is doing with it is a postprocessor replace on the string {member_group}. I just want the integer value. Is there an easy way to get an integer?
  • #2 / Nov 02, 2010 3:21pm
    Are you using PHP on Input or Output? That said,
    <?=$this->EE->session->userdata['group_id'];?>
    might be even easier.
  • #3 / Nov 04, 2010 2:07pm
    rblitadmin
    That’s it. Thanks!
  • #4 / Nov 04, 2010 3:17pm
    Glad to see that helped. Post again as needed, please.
