orderby status ?
October 29, 2010 7:49pm
Subscribe [5]
  • #1 / Oct 29, 2010 7:49pm
    FlashBoyz
    I’ve created a custom status called “featured”. Is there a way for me to order(using channels:entries) entries by status?
  • #2 / Oct 31, 2010 3:51pm
    Greg Salt
    Hi FlashBoyz,
    No there isn’t, the channel://entries tag does not accept status as an orderby value. You could use the Query Module to do this though.
    Cheers
    Greg
  • #3 / Oct 31, 2010 5:11pm
    John St-Amand
    Or if you’re not comfortable doing that, and assuming you’re just looking to put your featured status items at the top and the rest below that, you can order within your channel entries tag - just use an if statement to look for your status to determine whether the item appears, then within that you can orderby and sort using normal methods. So:
    {exp:channel:entries channel="your_channel_name" status="feature|open" orderby="date" sort="desc" disable="whatever_your_can_disable_here" limit="20"}
    {if status=="featured"}
    put your featured items here formatting as you wish
    {if:elseif status=="open"}
    put your regular open items here, again formatted as you wish
    {/exp:channel_entries}
    All that would do is put your featured items at the top.  Alternatively you could simply put two channel entries tags in there separating featured from open entirely, which arguably would run a little faster perhaps since it wouldn’t have to first parse the conditional.  I’ve done it both ways, depending on what i needed to do since queries are outside my comfort zone.
    Hope that helps you!
    Jean
  • #4 / Nov 01, 2010 8:10am
    Thanks for the assist, Jean.
    FlashBoyz, It depends on what you want to do with the content after you get it. If you just want the featured items first, I’d do either two queries or two exp:channel:entries.
    Does that help?
  • #5 / Nov 01, 2010 1:10pm
    FlashBoyz
    Thanks guys. Yeah, I was just looking for an efficient way to display my “featured” items first. Didn’t want to go the custom field route because I like to see the custom status highlights in the CP. I think I’m just going to opt for the conditional. Thanks!
  • #6 / Nov 01, 2010 5:54pm
    Glad to see you found a way. Please post again as needed.
