Forum Module - Preview Topic/Post - Blank Page
October 28, 2010 7:04pm
Subscribe [4]
  • #1 / Oct 28, 2010 7:04pm
    hd
    Using the latest forum module with EE 2.1.0 and the preview post/topic buttons yield a blank page. Turning on output debugging works, but gives me no hints as to why no HTML is being spat out above the debug info.
    I am using PHP in my templates, and I’ve tried switching back to one of the default templates but with the same result.
    Any ideas?
  • #2 / Oct 29, 2010 10:37am
    Can you try to upgrade to EE 2.1.1? Make sure to be on the last version for both the forum module and EE.
  • #3 / Nov 01, 2010 11:34am
    Stamp Idea Group
    Upgraded the client to the latest build of EE (20101018), and the Forum module as well.
    Still having the same issue with the preview page being completely blank.
  • #4 / Nov 01, 2010 11:35am
    hd
    We’ve also tried disabling PHP in the forum, with no improvement.
  • #5 / Nov 01, 2010 11:52am
    hd
    Just discovered that this only appears to be an issue when using the {exp:forum} tag… Which unfortunately is pivotal in this site.
  • #6 / Nov 01, 2010 4:21pm
    hd
    We are now on EE build 20101020, with Forum build 20101018
    The problem is unchanged.
  • #7 / Nov 02, 2010 9:35am
    hd, with one of the default templates and PHP not turned on in the template, does the same thing happen?
  • #8 / Nov 02, 2010 10:17am
    hd
    Ok, after a bunch of testing, I found this occurs when using the {exp:forum} tag inside an embedded template. If everything is in the same template (a single template, no embeds), the preview pages function normally.
  • #9 / Nov 02, 2010 5:37pm
    What do you have in that template? If you’re running the forum through regular templates you shouldn’t have anything but the single {exp:forum} tag.
  • #10 / Nov 02, 2010 5:58pm
    hd
    I realize that now, was trying to push things a bit so that I could embed other templates before and after the exp:forum.
    Everything seems to be working fine in that regard, so long as the exp:forum tag is NOT in a template that is embedded (top level template).
  • #11 / Nov 03, 2010 10:37am
    So is that something you can live with for the moment?
  • #12 / Nov 03, 2010 12:36pm
    hd
    Yes, thanks.
  • #13 / Nov 03, 2010 10:01pm
    Glad you have a workaround. Don’t hesitate to post again as needed.
  • #14 / Nov 03, 2010 10:25pm
    hd - just to clarify, you can put those embeds directly into the forum themes themselves, exactly where you want them to appear.  That is what using {exp:forum} allows you to do - make the forums run through the full template parser so you can use those tags in the theme files. =)
