Is there an if statement limit?
October 27, 2010 4:42pm
  • #1 / Oct 27, 2010 4:42pm
    clearbytes
    Having trouble with a simple if statement.  It works for 7 if statements in a row… but if I add an 8th it ends up producing an empty entry.
    {if product-image1 !=""}Do something{/if}
    {if product-image2 !=""}Do something{/if}
    {if product-image3 !=""}Do something{/if}
    {if product-image4 !=""}Do something{/if}
    {if product-image5 !=""}Do something{/if}
    {if product-image6 !=""}Do something{/if}
    {if product-image7 !=""}Do something{/if}
    {if product-image8 !=""}Do something{/if}
    Is there a limit to if statements?  Do you know of another way of of doing this?
    Simon
  • #2 / Oct 28, 2010 4:27pm
    What version and build of EE are you using? There should be no hard limit here. That said, what are you trying to achieve? There might be a more efficient approach.
  • #3 / Oct 29, 2010 4:01am
    clearbytes
    Using version 1.7
    I’m trying to say:
    If custom field is not empty output that custom field.
    I need to do this 10 times in a row (Image thumbnails).
    Simon
  • #4 / Oct 29, 2010 12:04pm
    Yes that should definitely work. Can you show us a little more of your code? Are you using any extensions?
