Hi all,
Is it possible to assign the result of a query to a preload_replace variable? See my query code below:
{exp:query sql="SELECT cat_id FROM exp_categories WHERE parent_id = '{segment_3_category_id}' "}
{cat_id}
{/exp:query}Also, is there a way to set a custom delimiter to the exp:query output? In this case, I am trying to generate a pipe-delimited output.
Thanks, as always, any help would be greatly appreciated.
Rudy
Moved to CodeShare Corner by Moderator
