[SOLVED ] System Path Not Correct to Control Panel
October 23, 2010 11:20am
  • #1 / Oct 23, 2010 11:20am
    pilotstar
    SOLVED:  I changed the path in /system/index.php and should not have.
    I renamed system to a /newname.
    changed the path in /index.php
    changed the path in /newname/index.php
    At first I could get to the Control Panel, now I cannot
    Front end works fine.  Error message when going to
    http://discoveryflight.com/newname/
    is “Your system folder path does not appear to be set correctly. Please open the following file and correct this: index.php”
    Not sure what to do.
    Gary
  • #2 / Oct 23, 2010 4:38pm
    Glad to see you’re all set. Post again as needed, please.
