Links broken/ images missing in Control Panel after fresh EE2 install
October 21, 2010 12:41am
Subscribe [7]
  • #1 / Oct 21, 2010 12:41am
    madisonjds
    Moderator’s note: Split off from here
    hey Ingmar,
    i am having a very similar problem.
    i have the same menu backround problem as this user, and, in the channel’s publish and edit pages, i don’t get the text formatting buttons to come in visible. the box is there for them, i can even click where they “should” be and it will bold or link or whatever.
    i read the link to the troubleshoot, it talks about the file /cp_themes/default/default.css
    there was no default.css file in either the original zip file of EE2.1 or the server in that folder. i was at a loss as to where to get this from.
    i did try to move the folder to the system folder like the troubleshoot instructed, but it didn’t “find” it on it’s own, and i tried changing the themes folder path, but it produced errors.
    any clues?
  • #2 / Oct 21, 2010 3:43pm
    What version and build of EE are you using? Any extensions? You might want to try uploading a fresh set of files, including themes.
  • #3 / Oct 26, 2010 5:51pm
    sleven1868
    I am having the same issue. I just downloaded and did a fresh install of version 2.1.1.  I don’t have a default.css that came with my download in the themes\cp_themes\default\ folder. Does anyone have a solution for this issue?
  • #4 / Oct 27, 2010 8:22am
    The troubleshooting article contains inaccurate information. I’ve created a bug report on your behalf.
    To work around the problem, you may need to copy the entire /themes/cp_themes to your /system/expressionengine folder. Our apologies for this documentation error.
  • #5 / Oct 27, 2010 12:44pm
    sleven1868
    I tried copying the cp_themes folder into my system folder(i renamed the folder and updated my config file as suggested in installation instructions) and it still doesn’t work.  Is there another solution?  Or am I doing something wrong here?
  • #6 / Oct 27, 2010 2:37pm
    sleven1868
    I just redownloaded the Expression Enine 2.1.1 from the site and then reuploaded the themes folder and its all good now.
  • #7 / Oct 27, 2010 2:53pm
    Glad to hear it. What about you, madisonjds?
  • #8 / Dec 31, 2010 3:24am
    monster8
    I’m having the same problem. I’ve redownloaded EE2, reuploaded the cp_themes, uploaded cp_themes to my system folder and I’m getting no results. Please help!
  • #9 / Dec 31, 2010 4:15pm
    Belarga
    monster8, I just had that same issue as in previous upgrades. I uploaded the hole “themes” (previously changing the name to the online themes folder) and it worked fine without saving the cp_themes anywhere else… hope it helps.
  • #10 / Jan 01, 2011 1:20pm
    Greg Salt
    Hi monster8,
    Did Belarga’s tip help you with this?
    Cheers
    Greg
    @Belarga, thank you very much.
  • #11 / Jan 02, 2011 8:44pm
    monster8
    Unfortunately I still wasn’t able to get the themes working properly. I reuploaded the entire themes folder and it’s still the same. Am I missing a file?
  • #12 / Jan 04, 2011 3:39am
    monster8,
    What is your specific issue with the themes? Is your CP all looking unstyled or just certain parts?
    If your version is different to downloaded version you will need to do a version update and not just replace the themes folder which is also necessary.
    Have you got a link to your site you can share?
  • #13 / Jan 07, 2011 10:58am
    monster8
    John,
    I’m using EE2. The CP was completely unstyled with no images or css. It seemed like it just wasn’t finding the theme at all. I ended up fixing the issue by starting completely fresh and restoring the db and reinstalling EE all over again. I don’t know what the issue was but it’s working now. Thanks for your help.
  • #14 / Jan 07, 2011 11:29am
    Glad to see that worked. Please post again in case there’s anything else.
