If a channel entry has no category
October 18, 2010 4:27pm
  • #1 / Oct 18, 2010 4:27pm
    Burke Museum
    I am trying to write a conditional statement within the template code that will output different html if no category is selected. I can’t figure out how to write a conditional statement to see if no categories are selected.
    For example, I’m trying to accomplish something like this:
    {if categories}
      {categories limit="1"}
        {category_name}
      {/categories}
    {if:else}
      Event
    If a category has been sent it will display the category name, if not it will simply display “Event.” Is this something I can accomplish in the templating system, or am I going to have to use inline php?
  • #2 / Oct 19, 2010 3:51am
    Kevin,
    Welcome to the forums 😊
    This code is inside your channel:entries tag? Can you show us some more of the template?
    What does your URL look like for a category page
    Is this conditional to show a category name or Event for a number of listings or just once at the top of the page?
  • #3 / Oct 19, 2010 3:04pm
    Burke Museum
    Hi, thanks for your help.
    I’m using ExpressionEngine v2.1.0 Build:  20100810.
    Here’s a little bit more of the template code:
    {exp:channel:entries channel="events" start_on="{current_time format='%Y-%m-%d 00:00'}" orderby="entry_date|event_enddate" sort="asc" show_future_entries="yes"}
      <h3>
        {if categories}
          {category_name}
        {/categories}
       {if:else}
        Event
      </h3>
    <p>  <div class="bk_event_description"><br />
        </p><h2>{title}</h2>
    <p>    {event_description}<br />
      </div><br />
    I’m not particularly concerned with separate category pages as of yet. This is simply to display the type / category of event for each event. eg: Lecture, Workshop, Tour, etc. If there is not category event it should simply be labeled as an event.
    Right now the result of the code above is that ‘Event’ is always displayed in the <h3> element because the {if categories} conditional never returns true.
  • #4 / Oct 20, 2010 4:38am
    Kevin,
    There is no shortened conditional for categories like that at the moment. It would make a good feature request though.
    The only thing I can think of here is to make a category called Event and make this the default in your channel preferences. That way if no other category is chosen it will always show Event at least.
