Can a Relationship Field only show status:Open posts to select from?
October 07, 2010 10:48am
  • #1 / Oct 07, 2010 10:48am
    tomwgf
    hi
    i have a add new page for Products with a Relationship Field so you can select another product to show on the same page. A ‘Or How about this’ box at the side of the page.
    The problem is that after a couple of years the ‘another’ product list is huge as it shows all OPEN, DISCONTINUED AND CLOSED products.
    When i just want to show OPEN.
    Is there a way to do this?
    thanks
    tom
  • #2 / Oct 07, 2010 4:26pm
    What version and build of EE are you using? Are you talking about the pull down menu in the control panel?
  • #3 / Oct 07, 2010 6:20pm
    tomwgf
    hi
    its ExpressionEngine 1.6.8.
    in: CP Home ›  Admin ›  Weblog Administration ›  Field Groups ›  Custom Fields > Field Group:  Products
    i have a custom field with a Field Type set to Relationship: Related Product 1
    i have set the Select display criteria for PUBLISH page: Sort by title, Descending,  All.
    Then when CP Home ›  Publish ›  New Entry >New Product
    This Related Product 1 field allows me to select a product from all the products i have ever listed.
    But there seems to be no way of getting the field to just list Status:Open products.
    Does that make more sense?
    thanks
    tom
  • #4 / Oct 08, 2010 4:14am
    tom,
    no there is no way out of the box to do this.I know what you mean by the list becoming unwieldy with a lot of items in it. There is however Playa which gives you filters for that list by category,status etc. It is a commercial add-on though and you will also need to upgrade to EE1.6.9
  • #5 / Oct 08, 2010 5:05am
    tomwgf
    hi john
    thanks for this.
    i’ll take a look at playa and upgrading.
    thanks
    tom
  • #6 / Oct 08, 2010 9:46am
    Very good. Please don’t hesitate to start a new thread in case there’s anything else.
