Title as link to a blog entry
October 03, 2010 12:48pm
Subscribe [4]
  • #1 / Oct 03, 2010 12:48pm
    serafico
    Hello,
    I’d like to have a separate weblog with entries which are short presentations of articles posted on different blogs.
    Is it possible to set the parameters for an entry/weblog so that the title of each entry is a link to the article on a different blog? The list of the titles on my blog would be a list of links to outside blogs. Possible?
  • #2 / Oct 04, 2010 9:37am
    Sure. The easiest method would be to have a url field, a text field set to hold that particular URL. You’d need to do three things:
    1. Set the field type to None.
    2. Warn the author to make sure http:// is included in the link.
    3. For that particular weblog/channel, set Admin ›  Weblog Administration ›  Weblog Management ›  Edit Weblog Preferences Automatically turn URLs and email addresses into links? to No.
    Then you’d build the exp:weblog:entries loop to display the title and the additional field you created.
    Does that help?
  • #3 / Oct 05, 2010 3:58pm
    serafico
    Thanks for reply.
    The problem is that the link in that particular url field is not nice - with this “http://”. Is it possible to set it as a “normal” title?
    And to make it clickable you have to set in the weblog preferences “Automatically turn URLs and email addresses into links?” to Yes.
  • #4 / Oct 05, 2010 4:10pm
    serafico
    A good example of what I want to achieve is the blog of Douglas Bowman
    http://stopdesign.com/
    Some titles of posts are “links” to other blogs and some are his own “articles”. But all of them are presented as “normal” titles of posts. I know it’s a WordPress blog, but the question is how to make it with ExpressionEngine?
  • #5 / Oct 06, 2010 3:06am
    serafico,
    Using stopdesign as an example here is how I would do it in EE. {custom_field} you would replace with your own field where you add the URLs
    <div class="article entry link" id="post-{entry_id}">
              <div class="date">
              <span class="day">{entry_date format="%d"}<span class="month">{entry_date format="%m"}<span class="year"> {entry_date format="%Y"}</span></span></span>
              </div>
              <h3><a href="http://{custom_field}" rel="bookmark">{title}</a></h3>
    <p>          <div class="body"><br />
                {summary} <br />
              </div></p>
    <p>        </div>
    Does that help?
  • #6 / Oct 06, 2010 11:34am
    serafico
    <a href="http://{custom_field}">{title}</a>
    That’s the solution! Thanks a lot, John!
  • #7 / Oct 06, 2010 2:53pm
    Glad to see John Henry was able to help. Please post again as needed.
