IE7 login problem
October 02, 2010 6:08pm
  • #1 / Oct 02, 2010 6:08pm
    j0han
    just found out that the login form (copied from the docs) I’m using on a 1.6.9 install doesn’t work in IE7. Has anybody else run into this? Any solutions?
  • #2 / Oct 04, 2010 2:47am
    j0han,
    Can you elaborate a bit on what you mean by ‘doesn’t work in IE7’?
    Are you getting an error message, JavaScript or otherwise?
    Are you testing logged out as SuperAdmin?
    What build of EE are you using?
    Are you using any extensions?
  • #3 / Oct 04, 2010 4:07am
    j0han
    Hi John,
    No errors, but the conditional on the result page gives me the content for logged off users.
    I’m not testing as a superadmin, use 1.6.9 and use a bunch of extensions
  • #4 / Oct 04, 2010 2:00pm
    Brandon Jones
    Hi j0han, a few questions:
    1. Do you have cookies enabled in IE7?
    2. Does this work in IE8?
    3. Are you running multiple versions of IE side-by-side?
