Hi there,
EE 1.68 is having issues. The server locks up and needs to be restarted every few hours.
I get the following in the log files.
Oct 2 00:09:04 speedbitz /USR/SBIN/CRON[28516]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -type f -cmin +$(/usr/lib/php5/maxlifetime) -print0 | xargs -r -0 rm)
Oct 2 00:38:57 speedbitz—MARK—
Oct 2 00:39:01 speedbitz /USR/SBIN/CRON[25839]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -type f -cmin +$(/usr/lib/php5/maxlifetime) -print0 | xargs -r -0 rm)
Oct 2 00:49:01 speedbitz /USR/SBIN/CRON[17612]: (root) CMD (cd / && run-parts—report /etc/cron.hourly)
Oct 2 01:09:02 speedbitz /USR/SBIN/CRON[11741]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -type f -cmin +$(/usr/lib/php5/maxlifetime) -print0 | xargs -r -0 rm)
Oct 2 01:38:57 speedbitz—MARK—
Oct 2 01:39:02 speedbitz /USR/SBIN/CRON[13621]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -type f -cmin +$(/usr/lib/php5/maxlifetime) -print0 | xargs -r -0 rm)
Oct 2 01:49:01 speedbitz /USR/SBIN/CRON[32465]: (root) CMD (cd / && run-parts—report /etc/cron.hourly)
Oct 2 02:09:01 speedbitz /USR/SBIN/CRON[19829]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -type f -cmin +$(/usr/lib/php5/maxlifetime) -print0 | xargs -r -0 rm)
Oct 2 02:38:57 speedbitz—MARK—
Oct 2 02:39:01 speedbitz /USR/SBIN/CRON[11997]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -type f -cmin +$(/usr/lib/php5/maxlifetime) -print0 | xargs -r -0 rm)
Oct 2 02:49:01 speedbitz /USR/SBIN/CRON[32254]: (root) CMD (cd / && run-parts—report /etc/cron.hourly)
Oct 2 03:09:02 speedbitz /USR/SBIN/CRON[14255]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -type f -cmin +$(/usr/lib/php5/maxlifetime) -print0 | xargs -r -0 rm)
Oct 2 03:22:01 speedbitz /USR/SBIN/CRON[9637]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts—report /etc/cron.daily ))
