Bizarre Pagination Issue
September 29, 2010 10:38pm
Subscribe [4]
  • #1 / Sep 29, 2010 10:38pm
    Trumpet
    So, I’ve got something pretty weird happening.
    In order to get my paginated search results rocking, I implemented the fix described over here: https://support.ellislab.com/bugs/detail/13536/. It seemed to work fine in my DEV environment, but for some reason the pagination isn’t working as expected on production.
    In fact, if you view the results for a search like “treme” using the simple search form at the top of the homepage - http://www.noraworks.org - you’ll see that the pagination links are displayed like “N10,N20,N30, etc.” Weird. This is what’s causing the issue, no doubt.
    But on the DEV site - http://dev2.noraworks.org - doing the same search displays “P10,P20,P30, etc.” Which works out.
    Anyone seen this before? Thoughts on how to fix? Running EE 2.1.0 (the August build)
    Gratitude in advance.
  • #2 / Sep 30, 2010 10:35pm
    Brandon Jones
    Hi Trumpet,
    Are both sites running the same build? Is there perhaps an .htaccess file doing URL rewriting on one but not on the other?
  • #3 / Oct 01, 2010 1:32pm
    Trumpet
    Actually, I just realized that the production site is running the July build and the development site is running the August build.
    I’m planning on upgrading production this evening, so let me see if that fixes it. If not, I’ll be back. Thanks!
  • #4 / Oct 03, 2010 7:35am
    Sounds good. Let us know what you find out. We’ll be here.
  • #5 / Oct 05, 2010 10:05am
    Trumpet
    Turns out, this was exactly the problem w/ the pagination. Upgraded to the August build, implemented the hot fix above, and good to go.
  • #6 / Oct 05, 2010 3:31pm
    Glad to hear it. Please don’t hesitate to post again in case there’s anything else.
