Problem Installing EE2 on a local MAMP server
September 27, 2010 7:23pm
  • #1 / Sep 27, 2010 7:23pm
    mprzybyla
    I have just purchased a copy of EE2.1.  I installed it on my Windows XP work machine earlier with no problems.
    Subsequently I tried to install it on my Mac (Snow Leopard) at home and no luck.  I’m running a MAMP local server and my problems seem to be similar to others I’ve seen in the forum.
    I used phpMyAdmin to set up a database, set the permissions, used the installer to install, and EE gave me a “installed correctly” message at the end.
    The only strange thing during the install was that I did not have the option to install the Agile Records theme from the drop down.  I could only do a clean install with no theme (I installed the Agile theme on my Windows machine earlier, no problem).
    This is the config that was written during the install:
    | ExpressionEngine Config Items
    | The following items are for use with ExpressionEngine.  The rest of
    | the config items are for use with CodeIgniter.
    $config['app_version'] = '210';
    $config['install_lock'] = "";
    $config['license_number'] = '';
    $config['debug'] = '1';
    $config['cp_url'] = 'http://localhost:8888/mysite/mysite/index.php';
    $config['doc_url'] = 'http://ellislab.com/expressionengine/user-guide/';
    $config['is_system_on'] = 'y';
    $config['site_label'] = 'Mysite';
    $config['cookie_prefix'] = '';
    // END EE config items
    | Base Site URL
    | URL to your CodeIgniter root. Typically this will be your base URL,
    | WITH a trailing slash:
    |    <a href="http://example.com/">http://example.com/</a>
    $config['base_url']    = '';
    After this, I tried navigating to the control panel, but I get this error:
    An Error Was Encountered
    Unable to load the requested file: account/login.php
    I tried adding the themes path to the config myself, as suggested on the forums, like so:
    $config[‘theme_folder_path’] = “/Applications/MAMP/htdocs/mysite/themes/”
    This is the correct and full path.  But instead of the error I just get a white screen of death.
    I don’t think this problem is even specific to MAMP.  I’ve also got a native Apache/PHP/MySQL environment running on my Mac and I tried the install there with the same result.
    Any help would be appreciated,
    Martin
  • #2 / Sep 28, 2010 10:36am
    Martin, which build/version of MAMP are you using?
  • #3 / Sep 28, 2010 8:13pm
    mprzybyla
    I’m running version 1.9 of MAMP, though in the end I think this has nothing to do with my local server setup but rather with the renaming of the system folder upon installation (as per the installation guide).
    I had renamed my system folder to the same name as my web root.  In other word, I installed EE in:
    http://localhost/mysitename/
    and then I renamed my system folder to the same name as my web root (“mysitename”).
    So my control panel login was at http://localhost/mysitename/mysitename/ ... This caused the install to fail.
    So basically,if you rename your system folder, rename it to something besides the name of your web root, and then the install works.
  • #4 / Sep 29, 2010 9:48am
    Ahh.. that would make sense. 😊 With local installs, I rarely rename the system folder. Don’t hesitate to post again as needed.
