Today, the team at Twitter is shutting down their basic authentication service. For all you active tweeters, this is a good thing. Third party services will stop asking for your login information. You will finally be able to change your password in a single place. And you can put a definitive, one click, end to enthusiastic spamming on your behalf. I for one, welcome that change.
We’ve updated the Twitter Timeline plugin so it works seamlessly with Twitter’s new requirements and meets the needs for the majority of the Community. For example, if you are displaying a user or public timeline, and the feed you are using is not private, all the updated plugin needs is a screen name and you’re good to go.
Please note that if you are using the Twitter Timeline plugin, the update is required. The old version will silently stop working.
Happy Tweeting!
