Troubles with nested loops
August 27, 2010 11:48am
  • #1 / Aug 27, 2010 11:48am
    lavagraphics
    I’m trying to load a product channel based on the url-title, but this doesn’t seem to work.
    I nest an image loop inside the channel loops, that works fine.
    But I do want to list another channel as well, could someone look into this?
    FIRST PART
    {exp:channel:entries}
    {body}
    <!-- LOOP TROUGH IMAGES -->
    {exp:channel_images:images entry_id="{entry_id}" limit="12" orderby="random"}
    <div class="thumb" id="thumb-{image:count}"><a href="http://{image:url:large}">" title="" alt=""]{image:url:small}</a></div>
    {/exp:channel_images:images}
    SECOND PART
    Needs to be integrated in the first part cause I need the {url_title}
    {exp:channel:entries channel="products-{url_title}" dynamic="off"}
    <div class="excerpt {switch="odd|even"}">
    <h2>{title}</h2>
    <p>    {if product-afbeelding}<br />
            {product-afbeelding}<br />
        {/if}<br />
        {product-body}<br />
    </div><br />
  • #2 / Aug 27, 2010 5:48pm
    Welcome to the ExpressionEngine forums, lavagraphics!
    Can we get a bit more information from you? Which version/build of EE2.x are you using? You can find that at the bottom of any control panel page.
    What exactly are you trying to accomplish? Normally you don’t nest exp:channel:entries tags.
  • #3 / Aug 28, 2010 5:04am
    lavagraphics
    Thanks for the reply
    I started to rethink my concept of nested channels (EE newbie). And now I use the url segment to accomplish what I need.
    This post can be closed for me 😊
    Regards
  • #4 / Aug 28, 2010 5:30am
    Glad you were able to figure out what the problem was. Don’t hesitate to post again as needed.
