Connecting to Databases in PHP
August 25, 2010 1:01pm
  • #1 / Aug 25, 2010 1:01pm
    sourcedesign
    I have just upgraded to EE2 and I need to connect via PHP to an external MySQL database sitting on the same server as our main EE 2 database. This was something that was easy to undertake in EE 1.
    If I turn on PHP in the template and try and connect to the database I get the following error message:
    Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 27098 bytes) in /htdocs/XXXX/system/expressionengine/core/EE_Output.php on line 308
    I have upped the memory allowed in the system index.php and various other places with no effect.
    Has anybody connected to another database using EE 2 and could provide me with some examples? I cannot find help about this anywhere!
    Thank you in advance.
  • #2 / Aug 25, 2010 2:43pm
    For some reason PHP here needs more than 64 MB. Where, exactly, have you upped the memory?
  • #3 / Aug 26, 2010 5:36am
    sourcedesign
    I have updated it to added ini_set(‘memory_limit’, ‘256M’); to the index.php in the root of the installation and also ini_set(‘memory_limit’, ‘256M’); to the system index.php.
    I also tried adding the line to EE_Output.php file.
    I also setup a .htaccess file and added php_value memory_limit 256M to it.
    However none of these change the error message that I am getting, it still says it is exhausted after 67108864 bytes (64MB).
    Will it be looking for memory allocation elsewhere?
  • #4 / Aug 26, 2010 6:49am
    Check with your host.. they’ll have more information on how to upgrade the memory setting.
  • #5 / Aug 26, 2010 6:57am
    sourcedesign
    I am the host 😉
    The site is sitting on our local server in my office I am are running Apple/MAMP.
    Any further suggests gratefully received, thank you in advance.
  • #6 / Aug 26, 2010 6:59am
    Here’s a link for Drupal that might prove helpful:
    http://drupal.org/node/207036
