[SOLVED] How to know if there are entries before calling exp:channel:entries?
August 21, 2010 6:29pm
  • #1 / Aug 21, 2010 6:29pm
    Rick Jolly
    I’m using EE 2 and I’m very new.
    I don’t want to display a list unless I have entries since I’d have invalid html:
    <ul>
       {exp:channel:entries channel="test"}
          <li>{title}</li>
    </ul>
    I can’t nest EE tags like this:
       {if no_results}
          <!-- Is there no opposite of no_results? -->
       {if:else}
          <ul>
                <li>{title}</li>
          </ul>
    Using PHP, I’d either do a count() query before getting the entries, or I’d get the entries first, and only if some entries existed would I print the list.
  • #2 / Aug 21, 2010 7:15pm
    Green Egg Media
    Rick Jolly -
    You have a few options. You could do something like this, for example:
    {exp:channel:entries channel="test" dynamic="no" limit="1" disable="categories|member_data|pagination"}
       {if count > 0}
          {embed="embed_template_group/embed_template"}
    Note that in the channel entries tag, I’ve restricted it significantly. Essentially, this to limit the load on the DB and just return a single entry, allowing you to determine whether or not there are any entries at all. If you need to know whether there are more than 1, you’ll need to modify the parameters. Then, in the embedded template, you would make the actual list, like so:
    <ul>
    {exp:channel:entries channel="test" dynamic="no"}
       <li>{title}</li>
    </ul>
    There are other options, but this one should work for you.
    Lance
    Green Egg Media
  • #3 / Aug 21, 2010 7:31pm
    Rick Jolly
    Thanks so much! That is exactly what I needed.
    If I still have your attention, another developer somehow added automatic html list tags to {exp:channel:entries channel="test"} and I’m wondering how to find this setting.
    So this:
       {title}
    automatically gets rendered as this:
    <ul>
       <li>title</li>
    </ul>
  • #4 / Aug 21, 2010 7:40pm
    Green Egg Media
    It sounds like the developer was either using a plugin or an extension of some type to accomplish this. This isn’t a built-in feature of EE, at least not one I’ve encountered, and certainly not one that’s documented.
    I recommend asking the particular developer who had done this how to do it.
    Lance
    Green Egg Media
  • #5 / Aug 21, 2010 7:51pm
    Rick Jolly
    Ok, thanks so much.
  • #6 / Aug 21, 2010 8:05pm
    Green Egg Media
    NP, glad to help.
