Related_entries call prints output??
August 12, 2010 10:07am
Subscribe [6]
  • #1 / Aug 12, 2010 10:07am
    UntitledStudio
    I have the following code:
    {exp:channel:entries channel="channel1" category="{segment_3}" dynamic="no" style="linear"}
        {related_entries id="channel2"}
        {/related_entries}
    For some reason this is printing the output
    {REL[267][channel2]VvIzefHrREL}
    If i remove the related_entries calls:
    Nothing is printed to the screen as you’d expect.
    What’s going on here? Am I doing something wrong? EE2.1, no custom modules except imgsizer which doesn’t touch the DB.
  • #2 / Aug 12, 2010 3:25pm
    Green Egg Media
    The id parameter for {related_entries} should be the short_name of the field that contains the relationship. It looks like you are trying to identify a channel, not a field.
    Also, this is not a reverse_related_entries call; rather, a standard related_entries usage. If you want to use Reverse Related Entries, you need to use the {reverse_related_entries} tag pair, and there is no need to specify an id.
    Lance
    Green Egg Media
  • #3 / Aug 12, 2010 4:10pm
    Thanks for the assist. Doest that help, UntitledStudio?
  • #4 / Aug 12, 2010 9:40pm
    UntitledStudio
    Thanks for your reply Green Egg Media.
    My mistake, my code is actually:
        {related_entries id="field_name"}
        {/related_entries}
    I incorrectly typed it above - I’m using fake channel and field names. Anyway - the channel name and field name in related_entries call are both correct. Removing the related_entries call results in the weird text being printed to the screen disappearing.
    With regards to the post title - is a moderator able to fix that? It should be ‘related_entries’ not ‘reverse_related_entries’
  • #5 / Aug 13, 2010 6:19pm
    Brandon Jones
    UntitledStudio,
    Is this code by itself in a template? Inside the related_entries tag pair you also need to specify the field of the related entry you’d like to show, such as {title}.
  • #6 / Aug 15, 2010 7:40am
    UntitledStudio
    I changed it so the entire contents of the template is this:
        {related_entries id="field_name"}hihi{/related_entries}
    This results in the following being printed to the screen:
    {REL[267][gi_entrance]qbYFUStyREL} hihi hihi hihi
    I removed the related_entries line and
    Changing to
        {related_entries id="field_name"}{title}{/related_entries}
    Results in:
    {REL[267][gi_entrance]QqHQcbGyREL} Item1 Item2
    Changing to:
    yoyo
    Results in:
    yoyo yoyo yoyo yoyo
    Changin to:
    {title}
    Results in:
    Title1 TItle2 Title3 Title4
    Now that I’ve done all these tests and confirmed what I’ve already stated above, how can I fix this issue? There’s clearly something wrong with either my DB or EE itself. What can I do to fix it.
  • #7 / Aug 15, 2010 4:35pm
    Greg Salt
    Hi UntitledStudio,
    Please try resaving one of the entries that is related to your channel1 entries. Does that entry then display properly?
    Cheers
    Greg
  • #8 / Aug 15, 2010 10:20pm
    UntitledStudio
    This issue has been fixed. I had to resave one of the channel1 entries. The relation field must have broken somewhere along the line for that entry.
  • #9 / Aug 16, 2010 6:16am
    May have been a cache issue. Re-saving the entry cleared it. All relationships are kept in cache. So if it happens again try clearing the cache first. Feel free to start a new thread if you have any more questions.
