Image Previews for Entries
August 06, 2010 6:56pm
  • #1 / Aug 06, 2010 6:56pm
    Deep Shah
    Is there a way I can create a page where I can show images in place of text which link to entries? (Instead of a page with a list of the names of the entries, I want a gallery with images which link to the respective entries)
    I found a page will gives instructions for creating what it calls “gallery entries”, but I’m not entirely sure if this will do what I want. (http://rockatee.com/blog/expressionengine-how-to-create-gallery-entries/)
    [Mod Edit: Moved to the CodeShare Corner forum]
  • #2 / Aug 07, 2010 4:02pm
    Greg Salt
    Hi Deep Shah,
    Yes, absolutely. I’ll move this thread into the CodeShare Corner forum so that you can get some community input but the basic procedure would be exactly the same as when outputting any custom field. If, for example, each of your entries has a custom field called ‘entry_image’ which contains the link to an uploaded file, you can wrap a link tag around an img tag with your custom field as its source (simplified example):
    {exp:weblog:entries weblog="my_weblog"}
    <a href="http://{path=%27template_group/template%27}{url_title}" title="{title}">{entry_image}</a>
    {/exp:weblog:entries}
    Cheers
    Greg
