PHP Error
August 03, 2010 9:40am
  • #1 / Aug 03, 2010 9:40am
    rcsm
    I am receiving a PHP error message whenever I publish a new blog post that reads:
    Undefined offset:  2 in /home/bixaldev/public_html/cmsys/core/core.functions.php(634) : eval()‘d code on line 19
    Any ideas?
    Additional note - the problem only seems to happen on some browsers/computers?
  • #2 / Aug 03, 2010 6:44pm
    Brandon Jones
    dpachner,
    1. Which version and build of EE are you using?
    2. While testing, please temporarily disable extensions using the green button in the upper right of the Extension Manager.
    3. Are you using PHP in your templates? Take a look at line 19 of your template.
  • #3 / Aug 04, 2010 12:15pm
    rcsm
    The site is using version 1.6.8, and there is PHP in that particular template.
    Come to think of it, I think that may be when the problem started to occur.
    Basically, I am using a single template for all of the blog content, and then serving up different markup depending on the segment variable. The problem was pagination. There did not seem to be a way to test a segment variable with pagination (P1, P2, etc), so I pieced together this script that does so (see below).
    Is there a smarter way to handle that conditional logic?
    the code is:
    <?php
    global $IN;
    $seg2 = $IN->SEGS[2];
    if ($seg2=='' || substr($seg2,0,1)=='P') :
    <body class="listing">
    <?php
    else :
    <body>
    <?php
    endif;
    Thanks for the help!
  • #4 / Aug 04, 2010 7:24pm
    Brandon Jones
    dpachner, as this is an issue with custom PHP code I’ll need to shift this over to the CodeShare Corner. I will suggest though that you take a look at whatever is on line 19 of your template.
