Allow EE Code funny
August 03, 2010 8:58am
  • #1 / Aug 03, 2010 8:58am
    SpectraDisplays
    I have a template called product_list which I want to embed in various product pages, so I have downloaded and installed Allow EE Code
    in my channel I have
    {exp:allow_eecode}
    {embed="embeds/product_list"}
    {/exp:allow_eecode}
    the template product list is this
    <table id="rounded-corner">
        <thead>
            <tr>
                <th scope="col" class="rounded-topleft">LED Display Model</th>
                <th scope="col" class="rounded">Colour</th>
                <th scope="col" class="rounded">Lines of Text</th>
                <th scope="col" class="rounded">Typical Chars Per Line</th>
                <th scope="col" class="rounded">Brightness</th>
    <th scope="col" class="rounded-topright">Pixel Matrix (HxW)</th>
            </tr>
        </thead>
      {exp:channel:entries channel="products_list" limit="10" textlines="1"}
        <tr class="{switch='even|odd'}">
            <td>{Model}</td>
            <td>{Colour}</td>
            <td>{textlines}</td>
            <td>{Chars_Line}</td>
            <td>{Brightness}</td>
            <td>{pixel_h} x {pixel_w}</td>
        </tr>
    {paginate}
    <div class="paginate">
    <span class="pagecount">Page {current_page} of {total_pages} pages</span>  {pagination_links}
    </div>
    {/paginate}
    </table>
    if I call the template directly from another template, it works.
    If I use the call from the channel, I only get the <THEAD> section, nothing else appears
    What am I doing wrong?
  • #2 / Aug 03, 2010 5:11pm
    {exp:allow_eecode} would go into your template, not the entry. That said I generally advise against using this plugin; there are usually better ways to structure your content.
  • #3 / Aug 03, 2010 8:08pm
    SpectraDisplays
    Im open to suggestions then 😊
    I need to generate tables in different positions on different product pages, but cannot see an easy way round this unless I can insert a template into the channel like this
    What other ways do you suggest?
  • #4 / Aug 04, 2010 6:11am
    SpectraDisplays
    well moving the {exp:allow_eecode} into the table template doesnt work!! it does even less - i.e no table at all!!!!
    and thanks for saying you would do it a different way, but please cannot someone expand on how I achieve what I am after but doing it a different way!
    As a newbie to EE, this sort of thing is very confusing and so far, pretty hard work just trying to figure out how to do it, so I appreciate that my question may seem trivial, but I can only read the manual, search the wiki so many times, if I cant figure out how to achieve something, then I have no alternative but to post here!!
  • #5 / Aug 04, 2010 1:42pm
    Matrix might be something you could look at. Look for it over on http://pixelandtonic.com
