make segment string uppercase
July 30, 2010 8:52pm
  • #1 / Jul 30, 2010 8:52pm
    Tried searching the forums but did not find anything relating to my question (sorry if I missed it)
    Could someone tell me (if it is possible) how to take the segment_1 and make it uppercase?
    calling for {segment_1} in my template displays about ; I would like it to show ABOUT, or even About
    Thanks in advance!
  • #2 / Jul 30, 2010 9:34pm
    Welcome to the forums!  I’ve moved this to the CodeShare Corner.
    How about using a CSS text transform? You can read about it on w3schools.com.
  • #3 / Jul 31, 2010 1:14am
    trenchard
    CSS will work or you can use PHP (process on output) in the template…
    <?php
    $str = "{segment_2}";
    $str = strtoupper($str);
    echo $str;
  • #4 / Jul 31, 2010 1:32am
    <?php
    echo $str;
    Excellent! Worked perfectly.
  • #5 / Jul 31, 2010 11:57am
    trenchard
    You can actually parse PHP on input also if you need to since the segment variable will be parsed very early.
  • #6 / Nov 22, 2012 9:06am
    Dotwebs
    I found this while searching for the same. I’ve taken Lisa’s advice and used the css property in a span because I wanted the segment to appear in the middle of a sentence. This is a better solution if you don’t want to use PHP in your templates.
