EE 2.x and Query Strings
July 27, 2010 9:42pm
Subscribe [6]
  • #1 / Jul 27, 2010 9:42pm
    Wes Rice
    I’m using structure on my website. Structure creates page uri’s for me. In EE 1.6.x I could append query strings to the end of my page uri and use php or a plugin to get the value of the query string variable.
    http://www.website.com/url_title/?variable=value
    In 2.x, I cannot do this. It seems as if /?variable=value is parse as a segment. Did this functionality change from 1.6.x to 2.x or is this a bug?
  • #2 / Jul 28, 2010 3:46am
    lockwesmonster,
    I am asking the devs about this one and will respond here in this thread when I have a reply. Thank you for your patience.
  • #3 / Jul 28, 2010 12:21pm
    Wes Rice
    Thanks John. Getting variables from url query strings have been CRUCIAL to the success of business, so much so that I would revert back to 1.6.x for their use.
  • #4 / Jul 28, 2010 4:36pm
    Thank you for your patience. Our devs are looking into this.
  • #5 / Jul 28, 2010 5:15pm
    Your server may/may not support it.  But it’s easy to find out- in your system/ee/config/config.php file- find
    $config['uri_protocol']    = 'AUTO';
    Try changing it to PATH_INFO- which is the most likely to work.  Double check your segs and your get array.  And if PATH_INFO doesn’t do it, REQUEST_URI or one of the others may.
  • #6 / Jul 28, 2010 5:47pm
    Wes Rice
    PATH_INFO did the trick. Thanks a ton.
  • #7 / Jul 28, 2010 5:49pm
    Woot!  And- looks like your question helped out a number of other folks as well.  😉
