RSS 2.0 feed not working since updated to EE 2.1.0
July 27, 2010 9:13am
Subscribe [4]
  • #1 / Jul 27, 2010 9:13am
    James Mattison
    This has been working fine up until I upgraded to EE 2.1.0. Can anyone take a look and see if I’m missing something obvious.
    Link to RSS feed:
    http://www.jamesmattison.co.uk/index.php?/blog/rss_2.0/
    {preload_replace:master_channel_name="blog"}
    {exp:rss:feed channel="{master_channel_name}"}
    <?xml version="1.0" encoding="{encoding}"?>
    <rss version="2.0"
        xmlns:dc="http://purl.org/dc/elements/1.1/"
        xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
        xmlns:admin="http://webns.net/mvcb/"
        xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
        xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
        <title>{exp:xml_encode}{channel_name}{/exp:xml_encode}</title>
        <link>{channel_url}</link>
        <description>{channel_description}</description>
        <dc:language>{channel_language}</dc:language>
        <dc:creator>{email}</dc:creator>
        <dc:rights>Copyright {gmt_date format="%Y"}</dc:rights>
        <dc:date>{gmt_date format="%Y-%m-%dT%H:%i:%s%Q"}</dc:date>
        <admin:generatorAgent rdf:resource="http://expressionengine.com/" >
    {exp:channel:entries channel="{master_channel_name}" limit="20" rdf="off" dynamic_start="on" disable="member_data|trackbacks"}
        <item>
          <title>{exp:xml_encode}{title}{/exp:xml_encode}</title>
          <link>{title_permalink=blog/blog_content}</link>
          <guid>{title_permalink=blog/blog_content}#When:{gmt_entry_date format="%H:%i:%sZ"}</guid>
          <description>{exp:xml_encode}{summary}{/exp:xml_encode}</description>
          <dc:subject>{exp:xml_encode}{categories backspace="1"}{category_name}, {/categories}{/exp:xml_encode}</dc:subject>
          <dc:date>{gmt_entry_date format="%Y-%m-%dT%H:%i:%s%Q"}</dc:date>
        </item>
    </channel>
    </rss>
    {/exp:rss:feed}
  • #2 / Jul 27, 2010 6:52pm
    Brandon Jones
    James, I’m just seeing a standard webpage there, not feed XML.
  • #3 / Jul 28, 2010 4:20am
    James Mattison
    yes, that’s the problem! it seems to be defaulting back to my /blog/index page rather than loading the RSS feed.
    The template is properly set up as an RSS feed page in the template so I’m not sure what I’m doing incorrectly.
  • #4 / Jul 28, 2010 4:27am
    James Mattison
    Preferences:
    Template Name: rss_2.0
    Type: RSS Page
    Enable Caching: No
    Refresh Interval: 300
    Allow PHP: No
    PHP Parsing Stage: Output
    Access:
    All member groups set to YES
    Enable HTTP auth: No
  • #5 / Jul 28, 2010 5:14am
    James,
    This works without the Query String
    http://www.jamesmattison.co.uk/index.php/blog/rss_2.0
    In fact your site seems to work without query stings altogether. you might consider turning it off. Was it on for a reason?
  • #6 / Jul 28, 2010 6:57am
    James Mattison
    Thanks John, that has solved the RSS situation!
    The only reason I can think of that I ‘might’ have turned ‘Force Query String’ to yes was when I was trying to remove the index.php part of the URL following the EE tutorial. I never managed to get that to work properly so I went back to the default settings and perhaps missed some of the items I’d changed.
    No I have a new problem to solve - a lot of my static images and links were placed with the full URL, including the query string… now I either have to rename all the links or find a clever method to point an image tag to the default upload directory.
  • #7 / Jul 28, 2010 4:58pm
    Perhaps a search & replace might work? A server-side rewrite rule could probably handle this, too.
