Mass Template panel save ?
July 26, 2010 12:04pm
  • #1 / Jul 26, 2010 12:04pm
    Aaron Harkenin
    Is there a way to “Save Template as File” option enabled templates to mass update every once in a while? because ive found out (later on) that if you wont go back to templates and click save in template panel than they dont get updated to database which later results in lots of shocks.
    So What i want is to be able to chose all of the templates and mass save them (or update them) in template panel. It would be wonderfull if even i can time this some how so it will do this without my intervention.
    thank you
  • #2 / Jul 26, 2010 4:45pm
    In EE 2 you can use the Synchronize Templates option.
    This is not available in EE 1.
  • #3 / Jul 26, 2010 5:08pm
    Boyink!
  • #4 / Jul 27, 2010 2:05am
    Aaron Harkenin
    That module is what i was looiking for.
    I think from now on i should spend equal time to search my way in both ee and devotee.
    Cheers.
