Hi all,
I’ve got the Twitter timeline installed and I’m using it to pull in a twitter feed. It was all working perfectly until this evening when the tags simply stopped producing any content.
I’ve read in the built in doc that checking for errors is possible using the “Template Parsing Log” but I can’t find a reference to that in admin under “Output and Debugging Preferences”.
Any ideas? I’m using 1.6.9
John.
UPDATE: For a little while, if I swapped credentials to another account the plugin worked again, but not for the one I needed it to work with. Now, no account is working. I assume this is a Twitter issue but need to see those logs! 😊
