Error 1091 when updating the Discussion Forums
July 18, 2010 2:22am
  • #1 / Jul 18, 2010 2:22am
    Macrike
    Just upgraded from ExpressionEngine 1.6.9 to 2.1, and now I’m trying to upgrade the Discussion Forum module too, but when I click on the module I get the following message:
    A Database Error Occurred
    Error Number: 1091
    Can’t DROP ‘member_id’; check that column/key exists
    ALTER TABLE `exp_forum_read_topics` DROP KEY `member_id`
    Using MySQL 4.1.11 and PHP 5.
    Any ideas? :S
    I’ve looked into the database and member_id is clearly there, so I don’t know what the problem is…
    When I was about to update to EE 2.1, where it says “We have detected that you are currently running ExpressionEngine version 1.6.9. If you are ready to update ExpressionEngine to version 2.1.0 click the link below:” I got a PHP error:
    A PHP Error was encountered
    Severity: Notice
    Message: unserialize() [function.unserialize]: Error at offset 2889 of 3748 bytes
    Filename: core/Installer_Config.php
    Line Number: 168
    Not sure if that’s related.
  • #2 / Jul 18, 2010 4:18pm
    Macrike
    Rolled back to 1.6.9 and repeated everything again; same result. :(
    Error Number: 1091
  • #3 / Jul 18, 2010 6:00pm
    Brandon Jones
    Did you also get the unserialize() error on the second try? I’d like to address that first to ensure the 2.1 upgrade went smoothly.
  • #4 / Jul 18, 2010 6:02pm
    Macrike
    Yeah, on the second try I got the exact same error. Although if I press Back and try again the error does not appear again.
  • #5 / Jul 18, 2010 7:53pm
    Macrike
    This is on a production server, btw. I’ve dumped the site and database over to MAMP, and tried updating to EE2.1 from there, and I got the same unserialize() PHP error prior to updating. AND, if I ignore the PHP error and continue with the upgrade, when it comes to upgrading the Forum module I get the same error as before.
    So I guess it’s a problem with my database?
  • #6 / Jul 19, 2010 1:41am
    Macrike,
    Are you using any add-ons/extensions on your 1.6.9 site?
  • #7 / Sep 19, 2010 4:47pm
    Patata_killer
    I have the same problem:
    Error Number: 1091
  • #8 / Sep 20, 2010 3:42am
    Patata_killer,
    I have replied to your thread here. There is no need to make multiple posts.
