channel_url in related entries: wrong value
July 16, 2010 3:09pm
  • #1 / Jul 16, 2010 3:09pm
    Lasisto
    There are two channels: news (with custom relation field related_map and locations.
    I put the following in one template:
    {exp:channel:entries channel="news" limit="1"}
    {related_entries id="related_map"}
    {channel_url}
    {/related_entries}
    The result for channel_url is an URL which is only configured in the general configuration. Neither the “news” nor the “location” channel has this value. If I change channel_url to channel_title I get the correct value for the location channel. Is this a bug?
  • #2 / Jul 16, 2010 8:39pm
    Brandon Jones
    Lasisto,
    Do you have a custom field named channel_url?
  • #3 / Jul 21, 2010 3:09am
    Lasisto
    Hi Brandon,
    no, I don’t have a custom field channel_url. I want to get the value from the channel’s path settings. Inside the entries tag this works, but inside the related_entries the variable behaves odd.
  • #4 / Jul 21, 2010 5:01am
    Lasisto,
    If I recreate what you have then the variable {channel_url} will show whatever I have in my Channel Preferences under Path Settings. So check this setting for your news and location channels. Clear your cache to see if this helps also.
  • #5 / Jul 21, 2010 5:09am
    Lasisto
    It was the cache! Sorry ...
  • #6 / Jul 21, 2010 5:11am
    No problems. Feel free to start a new thread if you have any more questions.
