Search problems
July 10, 2010 8:16am
  • #1 / Jul 10, 2010 8:16am
    kilbey252
    Hi
    I’ve tried to find a solution to this before but failed.
    My site is a wildlife photography site My Site and I want people to be able to search for images AND get back what they expect.
    This site is currently on 1.6.8 core but I have a licence for 1.6.9 but haven’t upgraded yet (and probably won’t unless I can sort out some of the fundamental problems I’m having with EE - most are probably my inexperience but I’m finding it all a bit of a hard slog and really need to simple things like searching to work before I go any further).
    The problem is this.  If I set the name=“where” to value=“word” it doesn’t respect spaces in search terms (unless you enclose the search term in “”) meaning that a search for RED KITE will return anything with the keyword RED or KITE - erroneous results returned.
    If I set the name=“where” to value=“exact” it hardly does an “exact” filter.  It now respects spaces but searches on parts of words too so that a search for OWL returns any image tagged with the word wildfOWL for example.
    What is the solution?  Am I doing something wrong?  Can you layer attributes to have both “word” and “exact”.
    Code below for search
    Dave Kilbey
    Main search code
    <div id="searchform">
    <form id='searchform' method="post" action="http://www.davekilbeyphotography.co.uk/"  >
    <div class='hiddenFields'>
    <input type="hidden" name="ACT" value="19" />
    <input type="hidden" name="XID" value="51c1d7b2d110e19703e88d86cae5f0883cc37e76" />
    <input type="hidden" name="RP" value="search/results" />
    <input type="hidden" name="NRP" value="search/;no-results" />
    <input type="hidden" name="RES" value="90" />
    <input type="hidden" name="status" value="open" />
    <input type="hidden" name="weblog" value="" />
    <input type="hidden" name="search_in" value="entries" />
    <input type="hidden" name="where" value="exact" />
    <input type="hidden" name="site_id" value="1" />
    </div>
    Simple search code
    {exp:search:simple_form search_in="everywhere" no_result_page="search/no-results" status="open" id="searchform" results="90"  where="exact"}
    <div>
    <input type="text" name="keywords" id="search" value="" /> <input type="submit" name="searchBtn" id="searchBtn" value="Search" title="Search" />
    </div>
    {/exp:search:simple_form}
    [Mod Edit: Edited out licence details]
  • #2 / Jul 10, 2010 3:35pm
    Greg Salt
    Hi Dave,
    The search module seems to be working correctly. You could switch the where parameter to “word” put a message above the search form to the effect that quotes are required to match a phrase like that. You can submit a Feature Request for a change to way that the Search module works. There is also a 3rd party alternative that you may wish to look at.
    Cheers
    Greg
  • #3 / Jul 11, 2010 6:43am
    kilbey252
    Hi
    Thanks for the suggestions.  The ideal short-term solution would be that when people type in a search it automatically gets surrounded by “” when submitted.  Is this possible?  Any ideas how I would do this?
    Dave
  • #4 / Jul 11, 2010 4:47pm
    Greg Salt
    Hi Dave,
    You would probably need to do this with some Javascript that could change the query before the form is submitted. I can move this thread into the How To forum so that you can get some community input into the best way to do this?
    Cheers
    Greg
  • #5 / Jul 12, 2010 11:41am
    kilbey252
    Hi Greg
    Going back to the original search problem I’m still puzzled how a search for OWL returns images tagged with wildfOWL with
    where="exact"
    set in the form.
    The documentation states:
    exact: only results containing the entire matching phrase will be returned.
    This clearly doesn’t work.  Could it be a problem with the core version?  Might installing 1.6.9 resolve the issue?
    Cheers
    Dave
  • #6 / Jul 13, 2010 7:38pm
    Brandon Jones
    Dave, please do upgrade to 1.6.9 so we’re on the same page. Now that I reread what you’re experiencing, that behavior does seem strange.
