I want to create a business listing channel where the state and zip code are dropdown’s. What’s the best way to do this?
July 05, 2010 3:04am
Subscribe [3]#1 / Jul 05, 2010 3:04am
#2 / Jul 05, 2010 6:40am
I use FieldFrame’s Select field type for this. It’s really easy to use and quite handy. If this is not what you meant in your post, feel free to correct me!
#3 / Jul 05, 2010 7:00am
Hey Liam
Thanks for your reply. I’m using EE2 so since Field Frame isn’t ported I’m guessing this functionality must be built into EE2.
#4 / Jul 05, 2010 7:04am
Field frame was not ported as EE2.0 has built a system similar to it - in other words that allows easier custom field type creations.
However, Brandon Kelly’s (Pixel and Tonic) select box now i think is part of either matrix or playa - cannot remember which. I know playa does offer support of this, but i think it is also related to pulling in other channels and multi selects.
There are however other field types for select and multi select drop downs - have a look at devot-ee to find the ones that are EE2 ported.
#5 / Jul 05, 2010 7:07am
Thanks nevsie. I’ll have another look at devot-ee to see what’s available. 😊
