[SOLVED] Expression Engine automatically appending paragraph element URLs into links
July 02, 2010 9:10pm
  • #1 / Jul 02, 2010 9:10pm
    tinyv
    Hi
    Got a weird issue with Expression Engine (v1.6.9) was looking for some help with.
    I added a bunch of entries to a weblog using a plain text Custom Field to store a URL.
    When I display this custom field in a template it automatically wraps the url in the element.
    I’ve come across the proposed solution at http://ellislab.com/forums/viewthread/130544/ , once applied works with any new entries.
    However, I can’t seem to apply this change to previously added entries, and worse if I try to edit this custom field in an existing entry then it still applies the element after saving. It’s cursed!
    For background information, custom field details as follows:
    Field Type: Text input (maximum characters 128)
    Default Text Formatting for This Field: None (+ Hide formatting menu)
    I’ve had a look at the database entries in MySQL.
    From what I can gather the information for this custom field is being stored in its plain text format (so the element is being added at display).
    Any suggestions gratefully received
    Thanks in advance,
    Cole
  • #2 / Jul 03, 2010 2:22pm
    Greg Salt
    Hi Cole,
    When you changed this field formatting type to ‘None’ did you see a notice and a checkbox at the bottom of the form asking whether you wished to convert all the existing entries?
    Cheers
    Greg
  • #3 / Jul 03, 2010 4:25pm
    tinyv
    Hi Greg
    Thanks for the reply. Had seen that in the post at http://ellislab.com/forums/viewthread/130544/
    The option to apply these changes to past entries didn’t appear.
    Is this a bug?
    Cole
  • #4 / Jul 03, 2010 4:53pm
    Greg Salt
    Hi Cole,
    You should be able to verify whether it’s working or not. Just go to your custom field manager and select the field in question. Change it’s type to any other and the option to convert existing entries should appear. If it does then go ahead and convert all the fields to something else ‘Auto BR’ for example and then immediately change the formatting back to None and convert them all.
    Cheers
    Greg
  • #5 / Jul 03, 2010 6:03pm
    tinyv
    Brilliant Greg
    Had obviously overlooked the *big red message*.
    Changed the text formatting to Auto
    then back to None and working fine.
    Thanks for the help and sorry apologies for missing the bleeding obvious.
    Cole
  • #6 / Jul 03, 2010 6:28pm
    Greg Salt
    Hi Cole,
    No problem at all. Glad that’s resolved. Please post back if you have further questions or problems.
    Cheers
    Greg
