Control Panel Theme Paths
July 01, 2010 5:41am
  • #1 / Jul 01, 2010 5:41am
    phil7085
    Hi all,
    I would like to know if there is a way to set different theme / template paths?
    For example. I have just installed a secure certificate on my site, I want the system area to be served via https.
    Using Plesk I have told the server to serve https files from the same directory as http. However when logging into the control panel browsers give a warning that the site is not fully secure simply because the images that the control panel are referencing in the themes folder are set as http://
    Is there a was to set the path for the control panel themes separate to the rest of the site.
  • #2 / Jul 01, 2010 8:09am
    Look for URL to your “themes” folder under General Configuration. See if that helps.
