Model for extracting member data including custom fields
June 24, 2010 8:20pm
  • #1 / Jun 24, 2010 8:20pm
    Badlands
    Hi, I’m trying to build a module that exports all the members data including custom member fields as a csv file. I would like the field title row to reflect the actual field name, not ‘m_field_id_22’ but rather map the field name ‘m_field_name’ from the ‘exp_memer_fields’ table to the corresponding field in the ‘exp_member_data’ table.
    As you can tell this is quite a complicated query and array to asemble given the abstracted nature of expression engine database fields.
    I am wondering if there is an inbuilt expression engine model that I could tap into to construct this query to help build the correct array for output in CSV formatting?
    Does anyone have any ideas about how best to construct this query?
  • #2 / Jun 24, 2010 8:58pm
    Brandon Jones
    Hi Badlands,
    If you take a look at the Member module, it does this very thing. Here’s how it does it (I’ve copied the code chunk into its own function for my own use):
    function get_cmf()
        $fields = array();
        $query = $this->EE->db->query("SELECT m_field_id, m_field_name FROM exp_member_fields");
        if ($query->num_rows() > 0)
            foreach ($query->result_array() as $row)
                $fields[$row['m_field_name']] = 'm_field_id_' . $row['m_field_id'];
        return $fields;
    Hope that helps. We may need to move this over to How-to if it doesn’t.  😜
