MySQL Error: 1054
June 17, 2010 3:09pm
Subscribe [4]
  • #1 / Jun 17, 2010 3:09pm
    Jeremy Latham
    I received this error after creating a new weblog & field group and trying to post. Have since deleted the weblog & recreated but still getting the error.
    MySQL ERROR:
    Error Number: 1054
    Description: Unknown column 'field_id_567' in 'field list'
    Query: INSERT INTO `exp_weblog_data` (`entry_id`, `weblog_id`, `field_id_567`, `field_ft_567`, `site_id`) VALUES ('695', '116', 'Test', 'none', '1')
    Can anyone point me in the right direction to fix this?
    EE 1.6.8 Build:  20090723 / MSM 1.1
  • #2 / Jun 17, 2010 3:55pm
    There seems to be an inconsistency in your database. Do you have a recent backup? Simply rolling back might be the easiest way to rectify this.
  • #3 / Jun 17, 2010 7:25pm
    Jeremy Latham
    Hi Ingmar - thanks for your reply.
    The most recent backup I have would still entail a fair bit of work to get everything back up to speed - a lot of info spread around a lot of sites, so if there’s a way that I can sort this out without going that route it would make my life a lot easier.
    It appears that I’m getting errors for field_id_567 & field_id_568. It won’t allow me to delete the custom field group that I created. When I try to delete the individual custom fields within that field group, these are the two errors I get.
    MySQL ERROR:
    Error Number: 1091
    Description: Can't DROP 'field_id_567'; check that column/key exists
    Query: ALTER TABLE exp_weblog_data DROP COLUMN field_id_567
    MySQL ERROR:
    Error Number: 1091
    Description: Can't DROP 'field_id_568'; check that column/key exists
    Query: ALTER TABLE exp_weblog_data DROP COLUMN field_id_568
    I’m a total novice when it comes to doing anything more than creating, importing, or exporting databases. But I’ve used EE extensively.
    Any help is much appreciated.
  • #4 / Jun 17, 2010 8:35pm
    Brandon Jones
    Hi Jeremy,
    Using phpMyAdmin, do an export (backup) of your current database to be safe. Then click on ‘exp_weblog_fields’ on the left, then click the Browse tab at the top. Then click the ‘field_id’ column to sort descending.
    Are there entries with a field_id of 567 and 568?
  • #5 / Jun 17, 2010 8:49pm
    Jeremy Latham
    Yes there are.
  • #6 / Jun 17, 2010 9:38pm
    Brandon Jones
    OK. You can remove those two entries. Then click on ‘exp_field_groups’ on the left, hit Browse, and you should see the offending field group (the one that won’t delete) in there. Go ahead and remove that as well.
    That *should* get you back to a normal, error-free installation. If so, again do an export of your database at this stage. You may be hitting a column limit of MySQL on your sever. What version of PHP and MySQL are you running?
  • #7 / Jun 17, 2010 10:16pm
    Jeremy Latham
    Thanks Brandon. You’re a star. I managed to delete the entries you instructed me on. DB is backed up again.
    I tried creating new custom fields and ran in to the same problem.
    PHP Version 5.2.13
    MySQL client version: 5.0.77
    Tech Support at Rackspace Cloud tells me that there is no column limit.
    Any ideas on where I can go from here?
  • #8 / Jun 17, 2010 11:44pm
    Jeremy Latham
    Hey Brandon,
    I found this thread that appears to be covering a similar problem.
    http://ellislab.com/forums/viewthread/152288/P18/
    As I mentioned, I’m really not particularly DB savvy. If I am running up against a limit because of innodb, can I simply toggle the switch for that table to change it to MyISAM?
    Any help is really appreciated!
    Cheers
  • #9 / Jun 18, 2010 12:39am
    Jeremy,
    You can run a SQL query in phpMyAdmin like the following. Just substitute your table_name each time.
    ALTER TABLE table_name ENGINE=MYISAM
    Back up db beforehand if you have not done so already.
  • #10 / Jun 21, 2010 3:39pm
    Jeremy Latham
    Switching the exp_weblog_data table to MyISAM seems to have fixed the problem, as in Boyink’s thread about a similar issue.
    Is there any long term issue having InnoDB for all the other tables and MyISAM for the exp_weblog_data table?
    Thanks for all the help you guys!
  • #11 / Jun 21, 2010 4:02pm
    I am not aware of any. If it works, don’t worry about it.
